SOURCE: voice mail icon stuck on
I had this problem on my pocket pc phone. FINALLY found the answer here: http://thedailyinvention.com/?p=565 hope that helps
SOURCE: How do I reset the passord for my voice message system?
intercom 777 *, *, 0, #, 12345678, # press 9 to admin, listen for mailbox administration, press appropriate number, then listen press, listen but it should be mailbox number thn 6 to reset !!!!! it deletes all messages. then reapeat for all extensions. listen to prompts after reset they should be all set to 12345678 #
SOURCE: How do I reset my
Depending on your cellular provider you may be able to reset your voicemail online by using their system to send you a pin or you can contact your provider for assistance and they will send a code that allows you to change your voicemail password.
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
To enter voice-mail, press your VM Key, the pass code will be set as default to 0000, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you are changing your voice-mail message, you must press 3, delete the original message and reset the message followed by the #. Please watch the video attached if you go to www.abbeytelecom.com there are over 60 covering lots of topics relating to the samsung dcs
