SOURCE: 1992 Honda Accord slowly accelerates
Sounds like a bad timing belt. timing belt may need to be replaced,or igniting timing may be off. here is a digram if you need help with timing .http://www.2carpros.com/car_repair_information/tec_info/1992/honda/accord/1992_honda_accord_timing_belt_diagram_marks.htm Good luck and thanks for using FIX YA.
SOURCE: misses during acceleration , rough
Go get the codes ran at auto zone or advance auto parts they will do it for free. If the codes come up as a cylinder miss-fire then it is most likely a coil (being a ford). Write down which cylinder it is. I wouldn't replace any of the spark plugs , useless you have more than 100,000 miles. If you have to replace the spark plugs use BOSH double plautim or better. The cylinder placing is ( as your are looking at the front of the truck) passenger side front to back 1-2-3-4 driving side front to back 5-6-7-8. If you never seen a coil buy one so you know what you are looking for. The coil is held in by a 7mm bolt. Take the bolt out and replace the coil. Problem Solved. Estimated time 20 Mins with 60 dollars per coil.
SOURCE: loss of acceleration and power on 2003 dodge ram 1500
The acceleration may be an issue with the clutch or with engine. If it is a manual tranny, you may have a worn out clutch. For automatic, you may need to have the solenoid cleaned or have the tranny serviced
Other issue could be on the engine, check first the fuel filter especially if you encounter loss of power when running.
SOURCE: 1993 Lexus Ls400 loss of power at 2500-3000rpm
Check your MAF and MAP sensor. The first 80% of your throttle signal from the TPS works with the O2 sensor to try to keep the air fuel ratio to 14.7 to 1 with the ECM controlling the fuel injector spray time and timing the ignition. After the 80% to WOT the ECM puts the O2 sensor in to an open loop and takes the Reading form the MAF and MAP sensor to run the engine richer so there will not be any Detonation to the engine and burning holes in the valves for running too lean. That is why it always feel like you get a little more when you ease off on the gas peddle from WOT. Recap check the TPS, MAF,and MAP sensor and wires to those sensors, if you can get the car scanned that would be great and you may find out which sensor may have gone bad, the other thing to is the fuel pressure regulator may be going bad and at WOT the pressure may be to high causing it to run to rich causing the loss of power. Good luck and hope this helps.
SOURCE: check engine light p0411 code what must i do
this has to do with your secondary air injection incorrect flow. start looking for a vacuum leak especially around the air duct from the mass air flow sensor to the throttle body.
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It
can be fuel pressure issue or it's the problem with accelerator pedal or its
clogged filters causing there.
There
are many other possibilities. I suggest you to go through the list of help
links mentioned below, these will help you to confirm where the actual fault
lies: -------
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
For Acceleration related problems,
Click
the link below to troubleshoot this problem: ---
Car loses power while
acceleration?
http://schematicsdiagram.blogspot.com/2011/12/car-loses-power-while-acceleration.html
Loss of acceleration?
Acceleration lag problem?
How exactly the Vehicles
Accelerator Cable works?
How exactly Vehicles
Accelerator Pump Diaphragm Works?
accelerator pedal sensor?
stalls and bucks on Acceleration?
Engine accelerates when brake is applied?
http://technoanswers.blogspot.in/2012/02/engine-accelerates-when-brake-is.html
This
will help.
Thanks.
----------accelerator pedal sensor?
----------stalls and bucks on Acceleration?
---------Engine accelerates when brake is applied?
-----------This will help.Thanks.
Click
acceleration?
This
will help.
Thanks.
Click
acceleration?
This
will help.
Thanks.
For
acceleration problem, the help links are provided below, click the link below
to go through its procedure: ----
applied?
How exactly the
Vehicles Accelerator Cable works?
How exactly
Vehicles Accelerator Pump Diaphragm Works?
Car loses power while acceleration?
This will help.
Thanks.
