Question about Kenmore Refrigerators
Kenmore Coldspot: Over a period of a month or so, the shelves are drifting on an angle away from the center of the fridge. Is this indicative of an underlying "big" problem?
Anonymous
SOURCE:
Anonymous
  • 195 Answers
SOURCE: Kenmore fridge Model# 106.56542400
Open the fridge side, look up.
Posted on Dec 07, 2008
Anonymous
SOURCE: Water dripping from top of fridge (coil housing?) under freezer.
I HAD LEFT THE DOOR AJAR ON MY KENMORE DPOUBLE DOOR WITH TOP FREEZER AND IT FROZE UP NOT ALLOWING THE WATER FROM THE NORMAL AUTOMATIC DEFROSTING PROCESS TO GO DOWN THROUGH ITS NORMAL DRAIN. THE ACCUMULATED WATER THEN DRIPPED INTO THE REFRIGERATOR UNDER THE FREEZER AND HAD TO BE SOAKED UP DAILY. THE SOLUTION--I REMOVED THE ADJUSTABLE
THATBOTTOM PLATE HAD AN UPWARD CURVED PORTION AT THE REAR. WHEN RE-MOVED, YOU COULD SEE FROZEN ICE ACROSS THE BACK UNDER THE VERTICAL COVER THAT COVERS COILS(?).
IN THE FAR BACK BOTTOM THERE WAS A FULL LENGTH, APPROX 1 1/2" WIDE DRAIN AREA WITH A HOLE IN THE CENTER THAT WAS PLUGGED WITH ICE.THAT WAS PREVENTING THE NORMAL DRAINING PROCESS.
A HAIR DRYER AND ABOUT 15 MINUTES MELTED THE PLUG, I THEN POURED A GLASS OF HOT WATER INTO THE HOLE AND IT DRAINED RIGHT DOWN LIKE IT SHOULD.
I HAD THE SAME FREEZE UP & DRIPPING PROBLEM A COUPLE YEARS AGO AND IT COST ME $100 FOR A SERVICE MAN TO FIX IT BUT IT'S REALLY A SIMPLE PROCESS TO FIX.
Posted on May 03, 2009
Anonymous
SOURCE: Kenmore Coldspot Model #71182100
water under crisping bins
Posted on Jan 25, 2010
Anonymous
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
aasc
Mike Smith
  • 1606 Answers
SOURCE: water leaks from freezer onto top shelves.
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or Copper solid wire , ( a ground wire or fence post tie ) 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Posted on May 05, 2010
Water beneath crisper at bottom of kenmore coldspot model 61184100
Usually cause by a blocked drain in the little trough in the rear of the fridge to catch condensation. Take everything out, remove the shelves, clean with a weak bleach solution and clean the drain.
Jan 23, 2018 | Kenmore Refrigerators
How many cubic feet is Kenmore Coldspot Refrigerator Model 10674254400 Serial ER3139075
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Apr 15, 2017 | Kenmore Refrigerators
Hello, we have drips of water coming in to the shelves of our fridge from the top. its a kenmore 106.71182100 coldspot. how can this be fixed?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 11, 2011 | Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water is forming in the "cool" part of the fridge. It's a 1998 Kenmore Coldspot. Is there a drain tube that might be clogged?
Yes, actually, there is. It should be located just below or behind the evaporator coils. You're probably going to have to take the shelves out and remove the ceiling and/or the back panel off to see it. Remember to disconnect the power, and good luck.
Apr 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Feb 08, 2010 | Refrigerators
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Loud banging noise and water leaking
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Feb 23, 2008 | Refrigerators
Refrigerators Logo
121 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
