It is common to cut off the fuel supply by stopping the diesel engine to shut off the transmission of fuel or air. The method is to install the solenoid valve on the pipeline of oil or gas supply, and control the opening and closing of the solenoid valve by pressing the electric button. So the solenoid valve is out of control. It can't cut off the fuel and air.
More technology supports, suggest you to contact the Starlight manufacturer( diesel generator set), they supply Cummins, Volvo, Perkins generator and provide services supports, the email address: [email protected].
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
SOURCE: The generator starts up runs for about 15 seconds and shuts down.
Check the oil pressure switch
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: 10kw Generac Guardian not cranking, shows rpm sense loss
Sounds like Generator mode switch should be "ON".
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
