SOURCE: PREFORMED NOZZLE CHECK
do you have a manual on this printer?
also, see this for more assistance
SOURCE: the oil sensor light continues to show
Its a good idea to have the oil pump's pressure output tested.
These cars are know for bad oil pumps.
SOURCE: My Kenmore Elite 79577563600 is showing Er 1F.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
SOURCE: Dishwasher showing Er . Reads as
ER code, that indicates a keypad switch failure.
If you confirm the error code and it is an ER UO code then the vent fan assembly will need to be replaced. If you can't verify the error code then I recommend a technician check this problem.
Below is a DIY self help Dishwasher repair help website.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
SOURCE: I do commerical refrigeration for
When your wine cooler starts to freeze things this way it usually is as a result of either the temperature sensor not functioning properly therefore not sending the trigger signal to the defrost sensor to signal when to start the defrost process. Or the defrost sensor not functioning at all. Although this could also be as a result of some short circuit on the board but most likely it is the temperature sensor or the defrost sensor. Get both of these checked and if possible replaced and your freezing issue is over.
Hope this solution has been helpful?
