Coffee Makers & Espresso Machines Logo
M
Michael Lim Posted on Mar 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Krups EA 8080 Coffee machine keep asking to clean the drawer a number of times even thought it is empty. Lastly but the machine indicate code 12. What does this code 12 meaning ?
Ross Keen
Level 3:
  • Krups Master 1,365 Answers
  • Posted on May 07, 2019
Ross Keen
Krups Master
Level 3:
Answers
1365
Questions
0
Helped
583198
Points
2445
Error 12 There was no pulse from the ejection switch so possibly a switch problem or worse still some grief on the control PCB. This will also be associated with the cleaning the drawer problem. From memory the switch/es are located above the used grounds bin.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Aug 31, 2012
SOURCE: I have an errorcode 06
water leaking from distributor. good luck
Joseph
Krups Ea8250 not heating. Getting automatic maintenance then pull plug and put back in.
open the machine, look at the wiring to the water heater. 1 cable is loose in the rubber/PVC cap. you have to solder it again.
Krups EA 8080 is stuck in machine filling mode
If it has no water flow check the pump. If it does have water flow then look for a leak or if no leak it's probably the distributor.
Hello, I have Krups XP-7220. When I try to make a coffee, machine start to ask me for refilling. And this process is endless.
Check the water float in the tank, it is common for them to cease floating sometimes. Krups solution is a new tank, my solution is to jam something plastic underneath it to lift it up so that it activates the sensor. Even if tank is empty it will no longer ask you to fill it up.
1helpful
How do I fix error code 12
That is a very uncommon error code. It is not detecting the ejection switch pulse, it may be just a case of dismantling and cleaning and checking the switch operation. It's all internal so you need to remove the housings.
Its about my Krups 8220. It gets stuck after it tells me to empty the two containers, immediately after cleaning the two containers and the coffee drawer it says machine in auto test and after it finishes...
Take it in to your Krups service agent, something is going to need replacing and they are by no means a simple machine to work on. You will fix nothing from the outside, it will need to be pulled apart.
1helpful
Krups ea 8260 espresso maker error code 07
Error code 05 on my krups ea 8260. How to fix it?
2helpful
2answers
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
