Vehicle Parts & Accessories Logo
rickid 21 Posted on Mar 18, 2019
My antenna keeps flashing blue and it’s not letting me pair my remote I have a Responder Technology sst antenna with the viper 7752v remote I just purchased. The old remote was damaged. How do I get the antenna to stop flashing so I can press the button on it so I can pair the remote to it.
Wally
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Sep 30, 2019
Wally
Contributor
Level 1:
New Friend:
Answers
28
Questions
Helped
11634
Points
60
Do a hard reboot so your new device can get the new ISP numbers download new device. Then try Bluetooth it you are trying to upload to car.
The
5 Related Answers
jason
  • 905 Answers
  • Posted on Feb 03, 2009
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Anonymous
  • Posted on Mar 14, 2009
SOURCE: wont pair
Press for long till blue and red flashes.
Anonymous
  • 3197 Answers
  • Posted on Jun 01, 2009
SOURCE: Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Anonymous
  • 53 Answers
  • Posted on Jul 12, 2009
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
logosc75
Larry Spears
  • 625 Answers
  • Posted on Feb 03, 2011
SOURCE: The Responder LC remote for
Plug the charger into an outlet. Plug the charger into the remote, unplug the charger from the remote. Repeat until "charge" appears on screen of the remote. You may have to repeat the process approximately five times until charge appears. There was an issue with the batteries in the remotes having to be reset. If this does "fix" the issue, your problem may be with the charger itself. You can use any usb charger to charge the remote, i.e. phone car charger, computer, etc.
Como cambiar la hora de mi viper 7752v
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
How to start my truck the viper has locked the system wont start
To manually disarm the alarm, turn the ignition on, press and release the valet switch. Start the vehicle.
Viper 5904 viper delete codes
Keep in mind once you erase you current remotes NONE of them will work until you program/pair them back again with your alarm. The 2-way remotes are different to pair than the 1-way. Having said that it's pretty simple to delete/unpair the remotes. I'm gonna try to keep it as simple as I can.
The alarm has to be disarmed and NOT in valet mode.
Step 1 open door (keep door open thru entire operation)
Step 2 turn ignition to ON position (not accessory)
Step 3 within 10 seconds press program/control button on antenna twice (push and let go, push and let go. DO NOT HOLD)
Step 4 NOW press and hold program/control button again (DO NOT LET GO) you'll hear siren chirp
Step 5 while still holding program/control button press the LOCK button on your remote control the siren will chirp again confirming remotes have been successfully deleted/removed.
Step 6 let go of program/control button
Step 7 close ignition switch to finish everything you did. NOW you have to pair ALL your remotes back to the system.
Hope this helps.
Funny thing same thing happened to me with the car option 1 and car option 2 remote.
1helpful
2answers
I just received a brand new viper 7752v remote and it will not power on even when plugged into the charger. I have tried to press the function key several times to reset it and nothing. Any Suggestions?
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
The blue light on antenae in car won't stop blinking and is distracting when driving at night. how can I stop this?
the only way i would know to stop it would be to unplug it from the modual. its just an indicater light so unplugging it shouldnt cause any problams.
1helpful
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
How can i program a new remote?
usually viper systems just need program button and ignition key. start by turning key to run then press the program button once then press again and hold. then press lock button of transmitter you want to add, parking lights should flash and then indicating that it is programmed. let go of switch and turn key off. try remote. good luck
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
