Repair, Calibrate or Request Field Service
Mitutoyo
https://www.mitutoyo.com > Contact Us
Whether you need immediate repair service or A2LA Accredited, NIST-traceable calibration of your measuring instruments, our highly skilled technicians provide ...
Mitutoyo Repair and Calibration
Indicator Repair
https://www.indicatorrepair.com > manufacturers > mit...
Indicator Repair repairs, restores, refurbishes and calibrates all makes and models of Mitutoyo indicators, micrometers, gages, calipers and levels.
SOURCE: squeaky plastic dial cover on a vw polo 2001
mcdevito75 here, Plastic expands and contracts with heat and cold, when plastic gets tired these properties weaken, If you can"t replace the cover try to use a little vaseoline jelly or a good penetrating oild WD 40 on it.
SOURCE: How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Hello. Mitutoyo has both calibration and repair services if required.
Repair:
http://www.mitutoyo.com/template2.aspx?id=22
Calibration:
http://www.mitutoyo.com/template2.aspx?id=21
Hope this helps out. Thanks.
