My problem is same like that what is above mentioned. After updating 4 led turned on no internet connection. Also doesn't open 192.168.1.1 . I had tried to open after reset not opening. WiFi connectivity was gone after update I doesn't find the WiFi after several searching on mobile and laptop. Kindly Help me. My Alcatel linkzone 4g model number is MW40CJ.
Hi, I have the same problem. Could you fix it eventually?
I'm facing the same problem. Did you get any solution.? please share
i m having the same issue
same issue.. any resolution for this?
Any update? I also have the same issue
Perform a hard reset.
Follow the link Robert provided and look under "Issues after updating" near the bottom of the page and click on "master reset".
Link?
have you found any solution, same device i have i also update firmware now same issue please help
Same issue..please someone can share steps how this can be resolved
You can try here
https://support.t-mobile.com/docs/DOC-32615
if that fails you might have to get in touch with the people you had it off
SOURCE: can,t access modem
disable all the fire walls
turn off all the security soft in urs pc
rescet urs modem 1s
then
try connecting the d link with the perfect jack to the perfect conector
thank you
SOURCE: Flashing power LED
If the download completed OK sometimes just recycling power will b enough.
Remember to try the default settings... (I.E. need to reprogram your new settings)
IF the system died during a download you may have permanently corrupted the microcode...
Call the vendor to confirm...
SOURCE: HOW WILL I RESTORE MY FIRMWARE
Hi, I have one of these ipod look alike players it's only a 1 gig version i bought for my daughter but she no longer uses it i can dump the Firmware for you and email it of to you if need be.
Other thing i can suggest is you try this site for help.
http://www.s1mp3.org/en/
Hope that helps.ttfn
SOURCE: n73i main camera not working
try this remove the back cover of the n73 and when u remove it u will see 2 small golden slim kinda plastic chip clean that and clean the 2 small golden antena's that looks like 2 small very small sticks clean it when ur done put back the cover restart ur phone w8 for ur phone to wake up slide the cover to open the camera and check it out it worked for mine too if it dosent work something's wrong with the 2 small antena's if u cant solv that problem go back to the same shop u bought ur phone and tell them to check it out if they cant find out tell them u want a nother nokian73 and try it out then thats it! :P
SOURCE: Airlink 89300 after firmware update, wan led is never active, and
After an "Update" you will have to set the router up all again, new everything.
Below is the link to help.
http://www.jensenscandinavia.com/routers/menu_al89300/index.htm
Have you found a solution?
YOU BRICKED IT IF YOU LEARN TO GOOGLE THIS
YOU SEE VAST OTHERS DID TOO, NOT JUST YOU.
STOP DOING THAT.
try this, if it is not broke don't fix it.
win
better answers, + above
gee do you or the ISP OWN THAT modem?.
99%do NOT, and if they do and you called them.
they'd tell you stop do not do that.
or it will be dead forever(or get charged $500 for new one as punishment)
in fact my cable modem, is auto updated by my ISP. (I own mine but they make the rules not me ever in this regard, and I know better me.)
stop updating any modems. ISP cable modems or the like, FIOS, 5G what ever... leave it ALONE. or simply reset it and configure the router correctly.
routers you own yes. for sure wpa3 upgrades.
in all cases, call the ISP, or you can be very vary sorry if you wreck their gear.
Any solution now how to fix it? Any firmware update steps?
