Took out filters & cleaned them No suction in hose when I remove to clean corners
It sounds like there is a clog in the hose itself if you have no suction from the end. If it is bagless remove the canister from the machine or if it is a bagged machine remove the bag. If you have a shop vac attach the hose from the shop vac to the end of the hose of the dirt devil and try to suck the obstruction out that way. Sometimes it is possible to remove the clog this way. You can tell if you have suction from the debris port to the bag or the canister. If not you may need to use a snake or coat hanger to pull the clog through.
SOURCE: no suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
SOURCE: Electrolux Bagless Canister Vacuum w/Self-CleanHEPA Filter - weak suction
Unfortunately alot of people buy this model because of the electrolux name, but it is actually made by eureeka. Aerus-Electrolux is the manufacturer of the high quality machines of our parents day.
SOURCE: Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
SOURCE: Brush will not turn and lights will not light
the problm is under the top cover of the base,there are some screws on the botton also remove the self adhiesive emblem on the top and remove the screw then the top will come off.ithink what you will find is a burnt circuit board that sets right above the motor
SOURCE: Very little suction in hose no tears in hose
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
