Question about Water Filters & Coolers
NIKAI NWD1208 Water Dispenser, problem about its refrigerator not working. Also, about its cooler & heater, its doesn't get hot nor cold. I'm finding it hard to look for its manual too. Please help.
    Top Expert:
  • 66,253 Answers
THEN PERHAPS JUST BIN IT AND GET A NEW ONE IS ONLY OPTION
Posted on Mar 10, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
Anonymous
SOURCE: Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Posted on Nov 15, 2008
Anonymous
SOURCE: Instant hot water dispenser does not heat water.
I had the exact same problem. I even replaced the first unit with a second unit...because I was sure I hooked everything up correctly. Then I called their support line and and felt very stupid. They asked one question "are you plugging in the Quick&Hot into the same electrical outlet as the garbage disposal"?. I said yes..and the garbage disposal works fine (thinking that this indicates a good electrical outlet). She then said "That outlet works off of a switch so no electricity is getting to the Quick&Hot until the disposal is turned on). Gosh darn it...that made total sense. I then tested this out by plugging an extension cord into a different outlet and it worked fine. Boy...do I feel stupid. Hope this helps.
Posted on Mar 19, 2010
tamurack
SOURCE: I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Posted on Mar 21, 2010
Anonymous
SOURCE: need owner manual for POLAR water cooler with fridge
how do i set the thermostat on my polar water dispenser.model#PWD335-
Posted on May 12, 2010
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
The water isnt cooling in the dispenser and we dont hear the coils running anymore either. what can we do to troublshoot our dispenser
It is oin the refrigeration unit, if it is not the power ie. outlet. Then not much you can cost effectively do. Could be compressor, dirty coils, thermostat or leaking refrigerant.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 26, 2009 | Avanti Hot and Cold Water Cooler
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Jan 01, 2008 | Soleus MW-55
Avanti water cooler
check the switch at back if it is working, check the motor compresor touch the top of the motor comp, if working, the possible problem is the freon, touch the condenser at the back of the unit if hot the freon is working, if no hot, load a freon, ok
Sep 28, 2007 | Avanti (WDE79BSS)
Water Filters & Coolers Logo
193 people viewed this question
Top Water Filters & Coolers Experts
tsalagi152
Irene Tulloch
Marvin
Marvin
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
