Refrigerators Logo
Senyo Awudza Posted on Mar 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why the first orange light and the green light of my hotpoint fridge model FUFL 1018 is on flashing
Marvin
Level 3:
Top Expert:
  • Hotpoint Master 85,242 Answers
  • Posted on Mar 09, 2019
Marvin
Hotpoint Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037252
Points
266281
There is a problem in the system, read the error codes.
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on May 04, 2009
SOURCE: green and red lights are on fridge not working
Hey, I see your model is made for the the United Kingdom. I live here in the USA and the UK just don't want to share their Hotpoint manuals with us. So if you like I can send you the links for information to sourses and suppliers and user manuals. If these links help let me know, Thank You, Sea Breeze
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Refrigeration/FFA60_FFA70_FFA80_FFS70.pdf
http://appliancejunk.com/forums/index.php?action=profile;u=3709;sa=showPosts
http://servicepartstec.blogspot.com/
Link: https://share.acrobat.com/adc/document.do?docid=f2313f51-aaf8-44ba-9876-aee21cf126ce
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=30055
http://www.howtomendit.com/answers.php?id=234766
efs_perpends
efs_perpends
  • 1997 Answers
  • Posted on Jun 20, 2009
SOURCE: error message 0xf0af8005 and green and orange flashing lights
Please follow these instructions to reset the printer. If that doesn't work, try again but wait longer before reconnecting. Otherwise, here's the home support page for your machine. You can look up the meaning of the flashing lights there as well.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Anonymous
  • Posted on Dec 09, 2009
SOURCE: light on top of fridge keep flashing
Hi I found the hotpoint site, from there i found the manual for my fridge freezer.
Robert Kitaji
  • 1335 Answers
  • Posted on Jan 21, 2010
SOURCE: canon i850 light is green then flashes orange 7
This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
caroldon
  • 17130 Answers
  • Posted on Aug 31, 2010
SOURCE: hotpoint aquaris wml 560, 1) all lights flashing
Possible that the inlet valve is not working or the ccontrol unit is faulty.
Please switch off and when switched on check for the voltage to the inlet valve, if water flows, if not the control panel is faulty.
If voltage is present and valve does not work then the valve is faulty.
Also check the DOOR switch( a safety switch) because if the switch is not working the control panel will not allow the control panel to proceed to switch on motor.
Also check and tighten all the connectors to the control panel.
2answers
Dometic CRE0050 fridge. The orange light flashing
The first thing I would do is check the battery voltage when the fridge is running. The trickle charger may not be enough. The voltage should be between 12.7 volts and 13.2 volts. Solar Trickle Chargers are made for trickle charging a battery that has no load. Also, they only charge during sunlight hours and your fridge is running 24 hours.
https://www.google.com/search?q=Dometic+CRE0050+fridge.+The+orange+light+flashing
1helpful
Both orange Light on top of hotpoint fridge keep flashing
Whats happen is the machine has gone into stand by because the doors was left open to sort it out what you need to do is
turn the freezer knob to off then turn it back on again this should restore it.
2answers
My hotpoint fridge fufl 1810 is not getting cold and keeps alarming with two flashing lights and is just over 15 months old any anybody help
Hey guys need some help please
me and my partner have just moved into our first flat and we brought a 2nd hand hot point fffl 1810 fridge freezer
the super cool n freeze are flashing and we cant reset them so we have tried these following
turned both dials to off and pressed n hold the buttons nuffink
turned back on left 1 hour and then turned the freeze one off and pressed both buttons nufink
turned back on for 1 hour and turned the fridge one off and pressed both buttons and nuffink
tooK both panels off on n checked to make sure nufink is blocked n the fan is working
anything else i could try please
1helpful
My hotpoint refrigerator keeps beeping,as if i have left the door open.There are three lights on the top two are orange,one green and the two orange lights are flashing as well.The fridge is not...
Hi Claire from retired Englishman in SW France,
Sorry but one thing that it means is that you have posted to the washing machine forum rather than the fridge one ;-0(
May I gently advise re-posting? With my experience of our fridges I could guess but it would be better to have proper FixYa expert help you ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
117helpful
4answers
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
