Televison & Video Logo
D
Debbie Hough Posted on Feb 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have UA40D5000 Samsung TV and it had a Black Vignetted band a Third of the screen running across the top of the screen
It used to come when first put on and now its permanantly there
Lawrence Oravetz
Level 3:
  • Samsung Master 10,558 Answers
  • Posted on Mar 02, 2019
Lawrence Oravetz
Samsung Master
Level 3:
Answers
10558
Questions
Helped
2696813
Points
29284
Sounds like some backlight led strips are failing. The led driver can cause that too. Go here for parts and led testers: TV Parts Universal TV Stands DLP Chips ShopJimmy
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Feb 18, 2008
SOURCE: "clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Anonymous
  • 113 Answers
  • Posted on Sep 27, 2008
SOURCE: phillips plasma tv MDL 42PF9966 Black Line across screen
The ribbon cable to the drive has either came loose of the drive itself went bad. You can open up the back if you are confident and see if adjusting the cable gets the line back. If not you will need to replace the Upper Y Drive.
Thanks
Josh
Anonymous
  • 1779 Answers
  • Posted on Feb 04, 2009
SOURCE: My 50" Plasma has developed a band across the middle of the TV
I would have it looked at before saying it is burn in, a BLACK horizontal line across the set is loss of data to the display from the Y-drive panel. This is something the customer should not attempt anyway, however, if it is either the upper or lower drive board they are not that expensive. Let me know the outcome.
Anonymous
  • 39 Answers
  • Posted on Feb 20, 2009
SOURCE: Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Anonymous
  • 22 Answers
  • Posted on Apr 28, 2009
SOURCE: Black line on Panasonic Plasma
go here and follow, it will work!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
2answers
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
1helpful
How to repair tv with lines on display
the samsung LNt 4661F has been known to develope flex tab bond issues which will cause line to run across the screen and you can also gt darker bands that run across the screen when the tab bonds fail. usually flexing the screen frame or a light tapping will allow the lines to disappear when its warm if its a tab bond issue
3helpful
3answers
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Acer TV Plasma screen problem
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Mitsubishi TV CS35313
bad caps in the vertical output and jungle IC section. Check all boards for black runs, leads near/on caps, they leak and eat the copper runs.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
