Televison & Video Logo
seema puri Posted on Feb 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The tv is not picking up any signal. - Televison & Video
Dakshinamurthy Nagarajan
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 89 Answers
  • Posted on Feb 28, 2019
Expert
Level 2:
Cheetah:
Night Owl:
Answers
89
Questions
0
Helped
22116
Points
201
Check up signal input connecting cable from dish.may be broken at the connector.
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152509
Points
4122
Make sure your antenna is plugged in, also make sure you've followed all steps to set it up including the "scan for channels" step that you access from your TV's Menu.
The tv is not picking up any signal. - ac76a8ab-a782-4e36-89d4-a8216e090c74-nm0tiheo3ogpzf5c4h5wl1la-3-20.jpeg
Cant stop tv from scaning
your tv might be an analog kind of tv and doesnt pick up digital signal since its an analog, secure a digital converter and set ur tv to channel 3 so u can pick up a digital signal and tv will stop scanning.
How to tune a tv channel
This could be too much signal.
Just to be sure though, try the set in another room where one of the other TVs works okay. This will help you see if it's a cable or a TV signal issue. If you pick up all the channels okay it's likely that that other TV point has some bigger signal losses due to the cabling.
The mux (transmitter channel) carrying the BBC signals will be amongst the strongest at each and every TV transmitter across the land. This is because the BBC and the main ITV channels have to reach about 96% of the mainland UK population in order to the broadcasters to fulfill their remit.
TV tuner sensitivity varies between brands and models. It may be that your old TV was just about okay with the signal power, but the new TV's tuner is over saturated.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Can't turn on my wireless on my Samsung smart tv so it pick up signal on router
Suggestion: Use WPS on TV and router. It self configures. Worked flawless for me.
Good Luck
My 50' sanyo plasma wont pick up hdmi signal
the problem on this tv is the main pcb , signal board
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Cant get channel 11 when i hook my converter box to this tv is there a way i can i get regular tv without it
No,if this tv is an analog tv mean tv have a big back cover and have a heavy CRT-(tv tube).Must have a good antena like a digital antena or move antena around to left or right to pick up channel 11,might lost some other channels than.This tv now can't pick up digital signal now without the tv converter box if u want to pick up free DTV air broadcasting tv signal,it all broadcasting in DTV free air in all digital now.
1helpful
Super Boss FM HI-FI Wireless Headphone SF878 no sound from the tv
Hi - the tv sound will be picked up like an fm radio signal at 83 mhz. To get there, press the reset button the side of the headphones, then press scan. the first signal to be picked up will be the tv signal. This assumes, of course that you have fresh batteries in the transmitter and headphones, and that the volume is turned up on the headphones and the TV. Worked for me. The signal is not stereo, though.
1helpful
Dont not pick up freeview channels
if u pick up NON freeview channels, i think the antenna isnt good enough to pick up the signal..freeview requires a very good signal, very important.
If you think this isnt the problem rescan the channels
If you think the TV is faulty contact Samsung directly
New TV won't pick up existing dishnetwork signal
Hope u are not working in the basement.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
