Question about Food Processors
Need sealing strip for Foodsaver V3880 - Food Processors
  • 1,645 Answers
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Posted on Feb 20, 2009
kiomi
SOURCE: Foodsaver 1050 - the metal strip under the tape is
Try elementsandteflon.com. or Hualian Packaging Machineries, Inc. You may find it there.
Posted on Jul 13, 2010
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: foodsaver vac800 not sealing bags any way to fix
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Posted on Sep 16, 2010
Testimonial: "20 mins. got my answer fast thanks"
Where can I get a replacement bag cutter for my food saver
Get them direct
http://www.foodsaver.ca
And instructions.
http://m.wikihow.com/Replace-the-Cutter-Blade-in-a-Foodsaver-Machine
Nov 18, 2015 | Food Processors
How do I freeze zucchini
The best way to freeze zucchini is to blanch it first. This allows it to stay firm and green in your freezer bags, while locking in nutrients.
  • Wash your zucchini and remove tops and any bad spots.
  • Cut zucchini into slices or strips.
  • Bring a pot of water to a full boil. Add the zucchini to the water. Leave in for 1 minute only.
  • Quickly remove it, and plunge it into a bowl of ice water. This keeps it from becoming limp and will stop the blanching process.
  • Pat dry until no water remains on zucchini. Excess water causes freezer burn and frost inside your bags.
  • Store in freezer bags according to size you want, making sure that all air is pressed out of the bag before sealing.
  • Mark bags with date, and you are done.
Jul 03, 2014 | KitchenAid KFP760 12 Cups Food Processor
Need to find a heat strip for seal a meal vz110
Model 750 seal a meal will not seal bags
Norm
Mar 09, 2010 | Food Processors
Leaking sinkmaster 850 garbage disposal
I have had these apart. The leak is from a seal around the motor shaft. By the time it is leaking the shaft has pitted to the point a new seal will not repair it. Getting it apart can result in damaged parts as it is sealed together with very tight tolerances and a glue like sealer.
Eric
Jul 02, 2009 | Food Processors
Foodsaver Profesional II heat strip transformer burned out.
The transformer can be found at a good wholesale electronics store, it is 12 volt and will register slightly higher with ohm meter. You can also use a 220 to 24 volt transformer.
Dec 04, 2008 | Food Processors
Need a rubber seal for my old Osterizer
I'm 55 years old and i have my granny osterizer blender how can i find a rubber seal
Dec 02, 2008 | Food Processors
Food Processors Logo
110 people viewed this question
Top Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
