Also a red light is blinking by the ice cube electronic eye on the upper right side of the freezer.
Hi! Please check the manual to this Thermador fridge https://manualsbrain.com/en/manuals/946658/?page=14
Hope it will help!
SOURCE: hotpoint side by side csx22grbk serial vz247504
chances are you have a faulty module (board) sounds like you'll have to call an engineer oput to replace it
SOURCE: Red light blinking inside freezer
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
You have a better chance of finding out that the problem is a broken moduele. The fingers that grab the ice and rotate it out they should be resting at the 2 oclock posotion. If stuck in any other posotion its broken. It's expensive but not hard to do. If you had a bad soloniod you would either have a frozen tube or a block of ice at the top
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
SOURCE: blinking red light on kitchenaid side by side no ice, but still have cold water
I had a blinking light, two flashes then pause, I did two things, not sure which worked, blow dryer to the black tube, and took a Q-tip to the sensor eyes (on both side of the walls), after a few minutes of trial and error, the light went out and I heard the water from the fridge, so hoping this would solve the ice maker issue!
Have the same issue. Did u figure it out?
has anyone figured this problem out? I have the same issue, Thanks!
