The stop/eject button works to stop but doesn't eject the tape. I have two cassettes inside the unit that I would like to remove. Is there a button combination I need to hit in order to have the tapes pop out?
SOURCE: Denon Dual Cassette Deck DRW-660 will not eject either tape
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
SOURCE: Cassette Tape stuck
The problem here is that the unit is stuck in a partial position. The "reset" by unplugging and plugging back in usually causes the unit to reset to a known position. If there is no activity (no motor sound), it will need to be opened up and reset manually. If you hear the motor running for a short period, it is attempting to reset, but the belt is most likely worn or broken. These units are relatively simple, but a bit tricky to dis-assemble. This repair should not require anything other than a belt or 2. Figure on $3-$10 for parts plus the local labor rate for the repair.
Dan
SOURCE: How do you hook up a sharp stereo cassette deck
If that tape deck of yours has an audio line out jack (like the RCA red & white holes, usually located at the back), get an RCA plug to connect it to your stereo receiver's line in jack..... or
if that tape deck of yours doesn't have an audio line out jack but, instead, has phones (or headphones) jack (usually located at the side or front of the unit), then get a plug to connect it to your receiver's audio line in jack (RCA type, also coloured red & white).. Usually the plug is small so you may have to use an adapter for your tape deck's phones jack.
BOB (June 23rd '12 3:45am)
