Question about ESCHMANN Little Sister Autoclave Tabletop
Eschmann SES 2000 Autoclave Steriliser doesn't drain
The autoclave goes through the entire cycle ending with "drying" but the water doesn't drain (it pours out when opening the autoclave). Does anyone perhaps know what the problem is and how to fix it?
    New Friend:
  • 35 Answers
Check the drain pipe that vents steam through resevoir at end of cycle , could be simple debris blockage, or vent valve not opening,play safe autoclaves are like accidents waiting for a place to happen -steam under pressure..
Posted on Feb 21, 2019
6ya staff
SOURCE:
kuuren
SOURCE: My sterilizing autoclave, SES 2000 Little Sister
Press any program button, hold it down, then turn on the power switch. Release it after 2 secs.
Posted on Aug 26, 2010
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: My autoclave ses 2000 turns
I would say that there is a problem with the thermostat. There is a small relay that pulls in to heat. And the relay opens when the thermostat reaches desired temp. I say it is the thermostat because it is pulling in the relay and heating. And if it is going to 107 degrees every time then the thermostat is pulling in the relay. So that tells you that the relay is working properly. So it would have to be the thermostat.
Posted on Sep 14, 2010
drhqaisi
SOURCE: i have a autoclave ses little sister 2 when l
dear sir
i need catalogue for little sister 2
thanks
Posted on May 30, 2011
emissionwiz
Marvin
  • 85222 Answers
SOURCE: ses 2000 autoclave showing h2o
You are in the wrong product section, thisis cars and trucks.
Posted on Jun 14, 2012
phil goldstein
SOURCE: 3870EA autoclave
Check the rubber door (safety locking device) bellows. If it is cracked it will leak
Posted on Aug 30, 2012
My sterilizing autoclave, SES 2000 Little Sister has flashed with error ELECT on the screen, it apparently has something to do with a power cut we may of had today, but how do you fix it?
Check the fuses located on both sides of the mains connection in the back of the autoclave. One of them has blown. If both check ok, then check the connection tho the mains. You may have a faulty ground. If you are not comfortable doing this, contact Eschmann at tel:+44 (0)1903 753322
Fax: +44 (0)1903 875789
info@eschmann.co.uk
Mar 06, 2018 | Science & Laboratory
Why is my autoclave not heating its water?
If you are not using purified or distilled water, most likely the heating element or sensor has become encrusted with lime or calcium and gives a false reading which will not allow the heating element to engage. (safety stuff you know) All you could try is a fill with a limeaway solution of 20%, cycle, drain and refill with distilled water, or disassemble and clean the components.
Jun 03, 2014 | VWR As12p Autoclave Accu Steam Sterilizer...
Error 3
Error 3 is a Door lock error and has nothing to do with the water sensor. Tighten the door down snuggly, but don't over-tighten. If it still doesn't work it may need a door rebuild or switch replacement. Call for service if it doesn't restart.
Apr 16, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Power failure
Might be several things. First though, verify that your power outlet can provide enough power that is specified to operate.
Mar 26, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Sun series autoclave
The connect wire might be broken or the print.....
Jul 17, 2013 | Science & Laboratory
What are some different ways to remove air from the autoclave?
downward displacement, steam pulsing, vacuum pumps, superatmospheric cycles, subatmospheric cycles. http://en.wikipedia.org/wiki/Autoclave
Apr 29, 2013 | Science & Laboratory
Ses 2000 autoclave showing h2o
Jun 14, 2012 | Cars & Trucks
Manual for little sister ses 2000 autoclave
do you recommend that the 1st cycle of the day be empty or is it ok with instruments in place?
Sep 06, 2010 | Health & Beauty
ESCHMANN Little Sister Autoclave Tabletop Logo
186 people viewed this question
Top ESCHMANN Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you an ESCHMANN Science and Laboratory Expert? Answer questions, earn points and help others
