Question about Water Filters & Coolers
I bought a stand up hot and cold water dispenser and there is a bare short wire coming out beside the plug. Is that the ground, and if so, where do I attach it?
    Top Expert:
  • 34,229 Answers
Attach it to the screw thats holding the outlets coverplate on in the center
Posted on Feb 06, 2019
6ya staff
SOURCE:
pipesster
Sean Lavelle
  • 21 Answers
SOURCE: My hot water heater has a red and a black wire,but
Your 220v hot water heater does not need the neutral(white) wire coming in. Bare wire goes to ground -green headed screw. Black goes to black, Red goes to red. White gets teminated with a wirenut or some electrical tape.
Posted on Jan 25, 2010
tamurack
SOURCE: I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Posted on Mar 21, 2010
al_kupchella
Al Kupchella
  • 843 Answers
SOURCE: The 3-way dimmer switch has 4 wires; 1-red,
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Posted on Mar 23, 2010
Anonymous
  • 5 Answers
SOURCE: I have a water dispenser that dispenses bottled
My name is Victoria and I work for Greenway Home Products. Sorry to hear you are having problems with your polar water dispener. Please feel free to call the customer service department at 1866-253-0447 or if you feel more comfortable, you can email me directly at vpeer@greenwayhp.com and we can try to rectify your problems with your cold water section. Hope this helps!
Posted on Apr 20, 2010
Anonymous
SOURCE: amtrol water heater WH-7P gets barely warm water
I had the same problem. I had a steam boiler and the water level in the glass gauge was below the top of the coil of the tank. remember water finds its own level, so it settled at the glass gauge level, therefore air got in coil.
to resolve problem : turned on manual water feed to boiler to raise water level. as water level got higher, let out water in hosecock between boiler and amtrol. amtrol noticed hot water reduction, circulator clicked on, boiler kicked on, turned off hosecock, turned off manual feed. I effectively bleed water out of line by running water out of amtrol as water feed in boiler increased water level above coil.
took a while to figure this out, so if this is the problem, dont feel to bad. keep water level of steam boiler high.
Posted on May 12, 2010
Whirlpool refrigerator ED2FHEXNQ00 - water shoots out the front
USE AT YOUR OWN RISK!!!!
I ACCEPT NO LIABILITY FOR PERSONAL INJURY OR PROPERTY DAMAGE.
YOU CAN BE KILLED IF YOU DON'T UNPLUG THE REFRIGERATOR!!!! EVEN AFTER UNPLUGGING IT, BE PRUDENT TO NOT TOUCH BARE WIRES OR TERMINALS.
If it is like my Kenmore, there are two solenoids at the back bottom right (facing the back) of refrigerator where the water supply connects to the refrigerator, and it sounds as if both solenoids (one for water dispenser and the other for ice maker) are energized at the same time as though the hot wires to the solenoids are shorted together. Possibly, if the replacement icemaker is not an exact replacement, a wiring difference might cause this short. ONLY IF YOU ARE QUALIFIED TO DO ELECTRICAL WORK will I suggest the following. YOU CAN BE KILLED IF YOU DON'T
UNPLUG THE REFRIGERATOR!!!! Disconnect one wire at a time by pulling and wiggling from side to side if the connectors are fastons , and with an ohm meter check for a short between the two hot wires of the solenoids. Remember where each wire goes. To determine which are the hot wires first measure each wire to a bare metal place on the refrigerator. Continuity between the wires (2) to the bare metal indicates ground. The remaining 2 wires are the hot wires. Continuity between these wires indicates they are shorted together, which is the cause of your problem. Seek out the short. Since I am not an expert myself, the preceding suggestion may not work if the short only occurs at the time that the icemaker calls for water.
I ACCEPT NO LAIBILITY FOR PERSONAL INJURY OR PROPERTY DAMAGE. YOU CAN BE KILLED IF YOU DON'T UNPLUG THE REFRIGERATOR!!!! EVEN AFTER UNPLUGGING IT, BE PRUDENT TO NOT TOUCH BARE WIRES OR TERMINALS.
Aug 16, 2014 | Whirlpool Refrigerators
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
I have been told that during a new installation you must install a ground wire from the hot water line to the cold water line??
The #6 bare copper jumper wire or ground wire between hot and cold pipes is to prevent stray household current from degrading metal parts of water heater and causing early failure of tank.
It's for your benefit and doesn't cost much, and may in fact be unnecessary .... except in cases where it is necessary which you wouldn't know until tank rusts out prematurely.
Here's some exciting additional reading:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#Ground-tank
Nov 24, 2010 | Rheem Water Heaters
My hot water heater has a red and a black wire,but the electric supply wires coming in to power the water heater have a red,black white and a bare ground. Which wires go where?
Jan 24, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Water won't get cold
next to the compresssor check for a solid copper obese tube, filter drier, touch this with your bare hands, and see if it is warm,if not the gas is not enough it being leaked from somewhere.
Recharge the system with freon gas.
Nov 17, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
MY HAMILTON BEACH WATER DISPENSER MODEL 87307 SERIES A1360CT WILL HEAT BUT NOT COOL THE WATER.
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Apr 21, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Water Filters & Coolers Logo
134 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
