Check the battery level and if low add distilled water to the max fill point. You could also try purchasing a Battery MINDer charger to help remove sulfated conditions within the battery, but this process is lengthy and may or may not work. If this doesn’t help rejuvenate your battery, it may need replaced.
It's called rejuvenating. Yes, it can extend the life of an old, dead battery, but not for long. If the battery will take a charge, it might work. Until it doesn't.
You know that motorcycle batteries are recyclable, don't you? When you buy a new one, they give you a discount for returning the old one. New batteries generally work a whole lot better than old, rejuvenated batteries.
a few bucks
a few bucks less
Sounds like the battery is not holding its charge.......you can rejuvenate the battery by fully charging and then fully draining til it goes off either by leaving on or using! Doing this a few times will allow the battery to fully charge and hold the charge better!
Yes! Rechargeable batteries can be rejuvenated by draining them fully and then recharging fully and then repeating a few times! The trick is to fully drain and fully charge!
The paper pick up fingers and rollers get smooth and polished with use and then slide on the paper. Clean the rollers and pick mechanisms with isopropyl alcohol to rejuvenate them and restore their grip on the paper. Do this as far along the paper path as you can get, using Q Tips where necessary and turn the rollers to clean their whole surfaces.
The picture tube emission is dropping causing the picture to become washed out, the rejuvenating process removes build up of crud from the guns exposing more emission material, this improves quality in the overall picture. But since the picture tube was done a week ago it suggests the guns have been stripped of their remaining material and the picture tube will get progressively worse over time.
There is a lock on the door mechanism. Unless the belts are good, the machine will not recycle to move the heads down far enough for the tape to be removed, so the door is interlocked to prevent damage.
Take the case off and push the door release and watch where the release lever hits a small nylon piece. You can pushit down with a pencil or screwdriver and the door will open. This white nylon piece will stay locked down if the blets are good and do not slip. They put the door latch in park allowing the tape to be inserted or removed.
Try to treat the belts with rejuvenator CaiKleen™ RBR Let them sit a while to get rejuvenated enough to not slip and the problem should be solved.
