Runco CL-420 Projector remote
SOURCE: Projector problems
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the
lamp´s temperature circuit. A technician disassambled my BENQ PB8253
unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
SOURCE: Hello with Sony VPL-CS1 projector in standby mode
overheated or lamp is past it's time. you may need to change the lamp, replace the lamp timer. while you're in there, clean it out.
SOURCE: Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
SOURCE: My RUNCO projector is projecting upside down and
1. Press the menu button on the remote to bring up the on-screen menu. 2. Select the Setup Menu 3. Select Picture Orientation 4. Change the configuration so that the image and text appear correctly.
