SOURCE: User Manual
Here is the direct link to your food processor user guide: http://useandcares.hamiltonbeach.com/files/840150200.pdf Enjoy Lolita
SOURCE: where can I buy repair parts for food processor
Call 1-800-851-8900 and order what you need directly from Hamilton Beach.
Please mark this as a fixya! thanks
SOURCE: I have a Cuisinart 14 cup food processor which will not turn on
Hi-
We have a Cuisinart and these tools are very rugged- so I doubt that the motor is bad. My only suggestion would be to make sure that the safety catch is being actuated when you click the cover clockwise to secure the mixing chamber. There is a hole in the housing that the acuator pin sticks into to disengage the safety switch. Perhaps the switch is not being pressed off.
Hope this helps,
Jeff
SOURCE: I want to open the base of the processor, but can't find screws
Remove the 4 rectangular rubber pads on the bottom.
Later you will need some Rubber Adhesive Glue to place them back.
This will give you access to the 4 Phillips screws.
I presently own a Cuisinart Food Processor Model# DLC-7.
I hope this helps you.
SOURCE: I am unable to remove the disc stem
My disc stem got stuck. I added boiling water to the bowl and left it a few minutes. After some jiggling of the stem it came off.
