Blenders Logo
R
Rosemarie Posted on Feb 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I buy a tamper for an Ambiano blender?
pacdave
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Feb 02, 2019
pacdave
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
34887
Points
318
Call 1-888-367-7373
Business Hours: Mon - Fri 10:00am - 5:00pm EST
Or email: [email protected]
1helpful
Where can I buy a Braun Multiquick-3 MPZ9 Tamper Proof Screwdriver
That model number is for a juicer and not a tool. What you should do is take a picture of the screw and go to a hardware store etc and show them. They can recommend a tool to remove it. Lowes, Home Depot, Ace etc.
How do you remove the bottom of the blender?
A inexpensive set of security bits from Harbor Freight contains compatible screwdriver heads. There are actually 4 tamper resistant screws- two are hidden under the rear rubber anti-skid pads.
Reset button blender
If they do have a reset button it is normally underneath.
1helpful
2answers
My Blender knives don't cut good anymore, what should i do?Can they be changed?or should I buy a new one?
Do you mean blender blades?
Either way, your blender blades/knives need to be sharpened.
This is the key to making your blender last a long time.
You may need to reach into the unit to sharpen them if the blade part doesn't twist off.
Good luck :)
2helpful
2answers
Krups 572 Power Xtreme VI Work Top
Repairing the blender:
My guess: You worked the motor too hard on your last blending session and it overheated. That will cause a thermal fuse inside to cut off. The blender won't work again until you replace the fuse but otherwise it should be fine. The fuse looks like a white diode and it will be attached tightly to the motor with a nylon strap (so that it can pick up the heat of the motor). The leads to the fuse are shielded with heat resistant nylon wrap. You will need to remove the rubber drive gear in order to remove the plastic house so you can work, although if you are really handy you might be able to at least test the unit by only removing the plastic bottom on the base unit.
To remove the plastic housing, remove the little rubber feet and then remove all of the screws on the bottom of the unit. You may need to buy a bit set for tamper resistant screws (I ***hate*** those), I don't remember. When the bottom is removed, you will see that the there is a screw head on the bottom of the central motor shaft. You can use a screw driver here to hold the motor from turning, then you can carefully use a pliers to unscrew the rubber drive gear on the top of the base unit (try not to damage the rubber). With the gear removed you can get access to the wires.
To test the fuse unit, just check its continuity. Short=good, open=bad. To further test, short out the fuse with a jumper cable and your blender should work.
EPO (Electronics Parts Outlet) in Houston, TX, has the replacement fuse unit. I don't know that they like mail order.
1helpful
Cusinert blender
you most likely have blown the thermal fuse. I just fixed my blender which had the same problem but only after I bought a another base:< If you are a handy person, it is a very simple fix. buy a 10 amp thermal fuse from "RadioShack" for $1.69. Sadly, it is cheaper to buy a new blender than have it fixed at a repair shop.
Top Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
john h
Are you a Blender Expert? Answer questions, earn points and help others
