SOURCE: how to unlock the child lockof electrolux washing machine EWF85743
Press and hold the curly symbol and the keyhole symbol at the same time until the lock symbol goes https://manualscollection.com/?fid=259d0fbc7e716abfa2176286e3ea57fe&read=online&page=10
Hey friend, thank you for your post!
Based off the information you have provided I see you want to access your drain pump. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your washer to gain access to your drain pump. Hopefully this is helpful. -Matt
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
