The handle and base of a kitchen fixture can work free after some time. A free fixture handle can meddle with the capacity of the spigot to turn on and off proficiently. Then again, a free base can move openly and cause the water lines providing the spigot to burst, causing a break. Fixing either of the two parts will incredibly diminish the aggravation related to a free kitchen spigot.
Eliminate any items in the sink bureau that meddle with your capacity to arrive at the two inventory valves situated at the rear of the bureau. Turn every valve clockwise to kill the stockpile of water to the fixture.
Inspect the fixture handle. You will either discover a setscrew with a recessed hex head at the handle base or beautiful covers snapped on the highest point of the handle or handles. You can also choose a residential plumbing Edmonton to solve your problem.
SOURCE: Can't tighten single handle moehn kitchen faucet
there is supposed to be a nut with a washer under the sink in the center, the metal plate is just for decoration, the nut and washer have to be installed before the sprayer is attached the stem that it connects to has threads on it for the nut your faucet should have came with a long socket made of plastic to install the nut
SOURCE: Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
SOURCE: How do I tighten a Delta kitchen faucet that has
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
SOURCE: Kitchen Faucet is loose on granite counter
http://www.needplumbingsupplies.com/Grohe-Kitchen-Sink-Faucets.asp?id=13758
This link has a spec sheet that will give you an view of under neath counter top. There should be a nut that you can tighten it up with.
SOURCE: how do I tighten a
There should be a large nut underneath the countertop, this may have loosened up. You will need a basin wrench, which will allow you to get into this tight area. Once you have the basin wrench engaged, turn the nut clockwise to tighten.
