Pritam patel Posted on Jan 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have error of license management error occured in Konica minolta bh-423. need solution please
Pensivania Pensive
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Mar 01, 2019
Pensivania Pensive
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
56887
Points
177
Where are you.
You can email me.
[email protected]
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Konica bizhub 423 red light blinking
If the red light is blinking on your Konica Bizhub 423, it usually indicates an error or issue with the printer. Here are a few things you can try to resolve the issue:
  1. Check the display panel: The display panel on the printer should show an error message or code indicating what the issue is. Check the manual or contact Konica Minolta support to find out what the error code means.
  2. Restart the printer: Try turning off the printer, unplugging it from the power source, waiting for a minute or so, and then plugging it back in and turning it on.
  3. Check the toner: If the toner is low or empty, the printer may not function properly. Check the toner levels and replace the toner cartridge if necessary.
  4. Check for paper jams: Paper jams can cause the printer to stop working. Check the printer for any stuck paper and remove it carefully.
If none of the above steps work, you may need to contact Konica Minolta support for further assistance.
Konica Minolta BH 601 error code 2401
A search using https://www.google.com suggests the following:
  • Code: C-2401
  • Description:The erase lamp (EL) is unconnected.
  • Causes:Erase lamp (EL)
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20601&code=C-2401
Web site above includes a link to a service manual.
2answers
Change the clock on a konica minolta bizhub 423
Go to cofiguration settings, scroll up/down to see the item you want to make changes.
Develop ineo 501, machine stopped, showing " have the fusing unit replaced soon, contact the service representative" -no error code. There is also "license management error occurs" but this promt was way...
that unit is manufactured my konica minolta. it is a Konica Minolta Bizhub 501 and will use the same fuser even though the image units, toners, and transfer belt have to be chipped for the ineo. There is a picofuse in the fusing harness that blows as soon as it is installed and that starts the fuser life counter. the counter is reset when a new fuser (or new fuse, if the fuser is still good) is installed. You will need to replace the fuser for the message to go away.
License management error occured (displays on screen)
Recommend you have tech come and see if he can re flash the copier Operating system not print driver Operating system for the copier is located on a secure web site only to dealerships and KMBS
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6helpful
Error C11A3 Konica Minolta BH 350
solution for error code c11a3 konica minolta bizhub 350 machine
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
