SOURCE: Lost my instruction manual for my Rival oval roaster
Need a manual for an olive green Rival crock pot, serial number 517 control number 3350610, very old, HELP SPC
SOURCE: Seeking Manual for Rival SS 18 qt Roaster Oven
Follow this link and you'll be able to view your roaster's manual in PDF format.
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
I hope this helps and Happy Thanksgiving! :)
SOURCE: New Rival 22qt. Roaster Oven
If you want to use it for food tomorrow, you need to burn it in tonight; 1 hour or longer at 400 degrees, outside but protected, to burn off the factory oils, etc. If you cook in it without doing this, you will ruin the food (and the atmosphere) with bad smells.
This turkey is really bigger than Rival recommends for this roaster, so check the size/fit tonight, also. You need an inch all around for best cooking.
I use 325, not 375 as the Rival manual suggests, 4 hours for an unstuffed 18 pounder.
SOURCE: what temp should i cook a 20lb turkey in a rival
This turkey is right on the edge of the size recommended for this roaster, so first,
check the fit- you need about an inch all around including the top to
get good cooking. Any place it touches the sides it will tend to
overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14
minutes per pound. In my experience this is too hot. I use 325 for 4 to
4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end
point temp (down quite a bit from a few years ago), but if you stuff,
that has to be in the middle of the stuffing, and the turkey will
overcook somewhat while it gets there. All experts agree that turkeys
cook better and safer if unstuffed, so considering that you will have
to make an extra pan of stuffing to have it for everyone, you would be
well advised to cook your turkey unstuffed and use some of the
drippings to flavor the pan of stuffing while the turkey rests.
SOURCE: Looking for manual for Rival Roaster Oven Model RO
You can find Rival manuals on their site:
http://www.rivalproducts.com/help.aspx?helpNav=5
Or contact them:
https://secure.rivalproducts.com/ContactUs.aspx
