Cell Phones Logo
A
Anonymous Posted on Jan 23, 2019
I want to use my HTC with my sim card how to change it from ic card to sim card
Khurshid alam shohag
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 23, 2019
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
19593
Points
37
Does not able this solution
3 Related Answers
Anonymous
  • 41 Answers
  • Posted on Dec 30, 2008
SOURCE: Nokia N70 Insert sim card problem.......
i can solve this
if you want to format your memory follow this:
menu>tools>memory>then press options>from the list select format mem.card.
Anonymous
  • Posted on Apr 24, 2010
SOURCE: E200 sim problem
tolong solusinya donk hp samsung SGH-E200 masukan kartu sim?????
virendar rawat
  • 195 Answers
  • Posted on May 18, 2010
SOURCE: my phone 6300 had not work sim card i change sim ic but no solve
hi if you have already change your sim ic and after doing this it doesn't work then you have to contact nokia service center they will help you
How to insert sim card
Hello:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Htc salsa no net work covery on sim
Hello My Dear:::::"""::
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Not recognizing SIM card
First All Check:
Last Option:
HTC SNAP SIM CARD FAILURE
First All Check:
Last Option:
Sep 01, 2012 • Cell Phones
1helpful
No sim card
Nokia C3 mobile shows no sim card means:
1.Might be your sim card got corrupt
2.Sim card slot in your handset may be damaged
3.Sim IC got damaged
these all are the reason for this problem
soluion
1.Check your sim on other mobiles.
2.Change you Sim slot after checking it.
3.Lastly check your SIM IC if neccesary change it
How to resolve a problem "sim card not inserted".
ITS INSERT SIMS PROUBLEM
FIRST CHANGE YOUR SIM
CHEK CONNECTION
PACKING
CHECK SIM SOCKET
RESOLD IT
THEN SIM ICS PROUBLEM HIT SIM IC
CHANGE SIM IC
JUMPER SIM IC
OR CHANGE IC
My phone 6300 had not work sim card i change sim ic but no solve
NOT READING SIMCARD
Martin,
Whenever a phone says Insert SIM means that its SIM reading IC is going or gone. It needs to be changed. Please have it checked and the IC changed.
Jan 30, 2010 • HTC G1
1helpful
3answers
3answers
Sim card failure
dear make it fulflash. try to use mt box
Aug 03, 2006 • Nokia 1100
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
