Heating & Cooling Logo
Kay Gentile Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed batteries in my remote Model No. HRC200 and now I can't get it to display temp and power. Can't adjust anything.
Bondedrepair
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 76 Answers
  • Posted on Jan 22, 2019
Bondedrepair
Expert
Level 2:
New Friend:
Night Owl:
Answers
76
Questions
0
Helped
35466
Points
175
Take a number 2 pencil eraser and clean the silver contacts on remote.
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86415
Points
1069
Is the Battery orientation proper or have you mistakenly inserted them the wrong way
3 Related Answers
Anonymous
  • 78 Answers
  • Posted on Nov 03, 2007
SOURCE: HRC200 shows current temp
http://12.153.20.74/manuals/119426-01A.pdf
page 24 shows to unlock hold both buttons down
Anonymous
  • 129 Answers
  • Posted on Dec 21, 2007
SOURCE: Remote 15-2144
Hello, you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Anonymous
  • 188 Answers
  • Posted on Jul 13, 2009
SOURCE: Model HRC200 remote
You cannot get lower than the 66 F. The manufacturer has set that as the default lostest setting.
I have replaced the batteries on. My model no:PP-SIRMT1. The device will not transmit the outside temp to the clock radio. What's next?
My pp-sirmt1 outdoor remote sensor display is blank and the clock displays "- -" for outdoor. I have changed both the remote and clock potteries even though they read "Good" on a battery tester. Can I purchase a replacement outdoor sensor unit?
tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
1helpful
I have a fujitsu a/c unit. Remote Model AR-RAH2U. If I push the on button, the a/c goes on-screen remains blank. I can not adjust the temperature or anything else. I have replaced the batteries.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display.
Hope answer the question
2answers
My kitchenaid works fine however I have hit something and when I press the bake button it shows 180 degrees instead of 350 all of a sudden. How do I reset it? I tried shutting off the breaker but that...
you neglected to mention the model this is , but most of the ovens made by them , when switched to bake , 1st show the temp you adjust then after thrirty seconds or so show the actual temp of oven (this number will change) the set temp function can be adjusted to anything in the ovens heat range 100-450) using the arrow keys anytime in the bake cycle , just touching a arrow key will change display to set temp screen , from actual temp display
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
1helpful
I replaced the battery in our HRC200 handheld it still does not work. We can turn the fireplace on with the manual control at the logs. The fireplace was used last season for the first time. Can you help?
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Model HRC200 remote
20helpful
6answers
HRC200 remote thermostat for gas fireplace
To turn on the remote you must press the POWER and LOCK buttons together.
Top Heating & Cooling Experts
Paul Carew
john h
