SOURCE: PS3 controller Problem
I just fixed mine. The controller itself needs to be reset. There is a reset button on the back of the controller, above the top right hand corner of the square with all on the information and barcode. Press it with a sharp tipped object while still connected to the PS3 via USB cable. Then press the PS button and you should be back on wirelessly.
SOURCE: Problems connecting a ps3 controller
Here's how to connect it tou your ps3. Mine works perfectly guys.
1. Turn your ps3 off without the USB key given with the controller
2. Make sure your controller is off.
3. Turn on the ps3
4. Turn on the controller
5. Press on the sync. button of your controller.
6. Plug the USB key into one of your ps3's port
7. When the light above your controller starting to flash slower, just pess the home button and your controller will be sync.
You can't turn on the ps3 with this controller. So turn it on manually than press the home button of the controller to turn the controller on.
If my post doesn't solve your problem, I really don't know how to solve it. I managed to connect mine so I hope it'll be the same for you!
Sorry for my bad English folks! You know... french people =S
SOURCE: PS3 does not detect controller even with a USB cable
hold down the ps button. and then connect a usb cable .
SOURCE: My Dual Shock 3 controller won't connect with the system
go into you accesory settings and change the controllers designation,change it to number 1, it will get changed from time to time cuz of drums or guitars being designated as no 1(especially mic's).
SOURCE: PS3 Wireless Controller for PlayStation 3: cannot connect my psyclone wireless controller to ...
There should be a sync button on the top back side of the remote. It's a little pin hole that you hold in for a few seconds with the system on. Please let me know if you're having further issues.
Its not letting me connect wirelessly. Red lights keep flashing.
How do I pair my Afterglow Wireless controller to my USB dongle?
Plug the new USB dongle into your PS3.
Now, press and hold the Home button (power button) on the controller until the LED on the USB dongle and the 4 indicator LED's on the controller are solid
