Use the stretch stitches. Triple (or reinforced) straight stitch. You must put length to “s.s.+” tension at 4
Use a zig-zag so the stitching will not pop when the fabric stretches.
SOURCE: stippling for Viking emerald sewing machine
The switch in the back will lower the feed dogs.
If you need a manual - I found a PDF download by googling: viking emerald 183 manual
SOURCE: How do I move the presser foot on a Husqvarna
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
SOURCE: i have a husqvarna viking
have you check your needle to see if it's bent
check to make sure it's threaded correctly
SOURCE: Thread easily pulls out of
You don't have the machine threaded correctly, make sure the thread is seated in the top tension, between the disc
SOURCE: I need a straight stitch needle plate for a
Hi Valerie,
Have you checked the Husqvarna website for USA? Following is a link to a page where you may be able to identify your needle plate & possibly order the part through the Husqvarna website.
http://www.husqvarnaviking.com/us/accessories_search_accessories_search_details.asp?ItemNumber=412288102
Please let me know if you need any further assistance.
Best wishes,
Graemevm
