The Toto has been working properly for over two years. Toto's advice: ship to them and they will repair it or $200! Any alternatives? Can one reset the Energy Saver schedule?
SOURCE: HOTPOINT BFI620 one led flash error
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
SOURCE: My screen acts as if it's on energy-saving-mode but doesnt activate...
Check and reset the Screen Saver to the settings you want, even if its set properly. Did this work?
If not, reset the monitor to factory defaults to flush its memory.
If that doesn't work unplug the monitor for a minute and replug.
SOURCE: LEDS are lit- one red, one green. no display, no boot
SOLVED!
This happing when trying to download a firmware upgrade or config from server and there is a power outgage.
Solution:
Put a file called cp7912r.zup in your tftpserver root. This file can be a valid cisco image, for example, CP7912080001SIP060412A.sbin
SOURCE: Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
SOURCE: KEYCODE light permanently lit on Citroen Relay van,
before u buy have trouble code scanned most auto stores offer service for free ==can be as simple as a bad key[not recognized] to big such as electrical anti -theft system
Testimonial: "Excellent and very fast - many thanks"
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
