Televison & Video Logo
A
Anonymous Posted on Jan 15, 2019
Hve a hisense 40inch led tv set is dead no power led on .nothing blown on power circt.Which is the quickest way to trace if the main pcboard is faulty?
Model of tv is hisense 50k220pw.I dont have remote of tv.tested from key power switch button on controle panel which tests ok.
matt martin
Level 3:
  • Hisense Master 1,259 Answers
  • Posted on Jan 16, 2019
matt martin
Hisense Master
Level 3:
Answers
1259
Questions
12
Helped
297109
Points
3635
You did not give a model number. I have repaired one of these sometime back. Look into the power supply. Find a single capacitor (fairly large) with a value of about 47mf at 160 / 200 volt (may be a yellow cap). It may have a small bulge. Replace this if you can. Remember I have no model number to exactly pin point. But, this is a very good tip. Thanks for asking, Matt of Martins TV Repair.
  • 1 more comment
  • Anonymous Jan 16, 2019
    thx the make and model is hisense 50k220pw.
  • matt martin
    matt martin Feb 02, 2019
    WITH NO LED STANDBY LIGHT...I WOULD BELIEVE IT IS THE POWER SUPPLY. IF YOU CAN DO IT SAFELY, TRY THIS. SOME FUSES WILL NOT LOOK LIKE A CONVENTIONAL FUSE. ON THE BOARD A FUSE WILL HAVE A LETTER F FOLLOWED BY A NUMBER,CHECK THESE. LVDS CABLES ARE THE RIBBON TAPE CONNECTIONS. THESE MAY BE REMOVED, SPRAY A CHAMOIS STICK AND CLEAN THE RIBBON END. CLEAN THE ACTUAL CONNECTION ON BOARD. yOU MAY HAVE TO LIFT A SMALL CLIP UP TO EXIT RIBBON CONNECTIONS....BE CAREFUL HERE, THEY CAN BREAK. REPLACE AND POWER UP AND SEE IF A STANDBY LIGHT COMES ON. WITH A VOLT METER SET A 200 VOLTS +. PLUG IN TV AND MEASURE THE HIGH VOLTAGE CAPACITORS. THESE CAPS WILL BE 160 VOLTS OR MORE....TEST THESE. TELL ME WHAT YOU FIND.
  • Anonymous Feb 02, 2019
    Thanks appreciate your input.I am getting the high.voltage on the imput high voltage caps of the pwer suply pcboard.on the output of the psuply pins I get a very low voltage 8.5volt or 9volts.The main pcboard dont hve 5volts.How do I isolate the pwersuply totaly away from main pcboard .To chek correct votages on pwer suply pcboard?to ensure pwersuply pcboard is 100 %?What voltages should I get?Hope my question is clearly understood.Apreciate your imnput, thanks again.Kind Regards
1 Related Answer
Anonymous
  • 4889 Answers
  • Posted on Nov 03, 2010
SOURCE: Visio p42hd, no picture
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
1helpful
3answers
Light blinking on and off button. Hisense 55 inch,,, model no.50r6e3
A blinking red light on the power button of a Hisense 55 inch model 50R6E3 TV could indicate a problem with the TV's power supply. It could be caused by a malfunctioning component, such as a blown fuse or failed capacitor, or it could be an indication that the TV is overheating. In some cases, a blinking red light can also indicate that the TV's firmware is not up to date and needs to be updated
2answers
Where would the fuse be located on my 55 inch hisense tv
Unplug the TV's power cord and hold the power button directly on the tv ,keep holding it for 20 secs or so then let the tv sit unplugged for a couple of minutes before you try it again.
1helpful
I have a hisense model 40k220pw led tv which has no power. Sw on power circuit looks good.nothing blown on power suply.how do I iliminate or isolate very quick to test if the main pcboard is faulty.
I see your problem and honestly I had a Hisense Tv so did my mother we bought the same type the same day and to be honest you will keep having problems out of their tvs , cause mine and my mothers rather got our apps to where the tv wouldnt support it no more , they will overheat and tear your system, not too mention you cant fix anything and their customer support are useless i would advise you to sale yours and get a good name brand smart tv
2helpful
Dynex tv
If your TV dead after the lightning, then your TV doesn't power ON with red light stays on lit you possibly have faulty main board.
If totally no indicator try to replace the fuse on power supply board if busted or blown (it is usually connected directly from power cord.
If the fuse still blown you need to replace the whole power supply board.
please rate!!!
Whirlpool microwave oven model #MH6150XMS - nothing works! There is no sound or light...nothing engages when bottons are pressed.
Remove the mains plug and check for a faulty/blown fuse. Remove the lid and follow the mains cable through the casing and to a PCBoard. On the PCBoard is a fuse, check that one. If it blows again, check the door interlock switches.
Hope that helps.
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
