SOURCE: I am installing a waterway supreme 2 pool pump
110v, 20 amp is called for in the instructions
SOURCE: 1.5 hp waterway champion pool pump issue
Be sure you have connected the motor to the line leads correctly and that the motor is set for the proper line voltage.
A somewhat common problem is that most motors are dual voltage (can be ran on 115 or 230 volt) and come factory set for 230 volts. If you connect it to a 115 volt circuit it will run for a while and then overheat and shut off.
SOURCE: waterway hi-flo above ground pool pump just
If it's rattely clean the impeller, If it's screechie bad bearing probally caused by a bad seal and it will need a new motor and seal.
SOURCE: can i buy just the impeller for the 1 1/2 hp waterway 2 speed pum
Yes, you can obtain the impeller separately. Feel free to contact us, or look online for your specific impeller part number.
SOURCE: I have a Waterway SVL56
That means that the connection between the motor and the actual centrifugal pump is broken. This is terminal: replacing the broken part will cost you more than the price for a brand new pump. Just cut your losses and replace it.
