SOURCE: Cuisinart CMW-200 Oven remains on and will not
Replace the door interlock switches. One is jammed on.
SOURCE: Fuse intact in supply lead but Neff H5470NO
Dead appliance, power on wall outlet. YOUR
SAFETY IS PARAMOUNT! Attempt
this only if you are competent. If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
SOURCE: I need to find the
Hello &
Welcome to FixYa You can buy
the motor from here or from here. Please get back to me if you have any other
questions. Kevin
SOURCE: Cuisinart microwave CMW-100. How do I change the lightbulb?
You need to remove the cover from the oven. Pull the plug first! Remove the Philips Screws. There are two special screws that are meant to prevent your proceeding further. No standard driver will fit these screws. You can remove them with small pliers gripping the outer edge of the screw and turning counter clockwise. If you are not familiar with capacitors, get somebody who is familiar. The light socket snaps in. Unsnap it. The lamp is taped to the socket with cellophane tape. I have never removed the lamp nor do I know the number. Do not plug in the oven with out the cover!!!!!
