My Stairmaster 4100PT stops the workouts at 20 and 5 minutes even though I select 60 minutes work outs. Any idea on how to discover the part that might have failed? The console? The power supply? Thanks.
SOURCE: Check paper size message even though paper size is correct
Make sure when you send the print job, that manual duplex options are NOT selected.
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
SOURCE: lifefitness 9100hr treadmill cut out
iv had similar problems, only happened once tho - i switched it on after a few mins
it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
SOURCE: stairmaster 4000 crazy console
Check all connections from power source in inside the cover where alternator is to upper display then if the problem still continues I suspect your upper console is going south. Call National Gym Supply @ 1-800-496-7278 they can either repair it or may have a exchange board for you.
SOURCE: Freecom Classic SL hard drive stopped working
Probable reason for failure of a disk is power, if the power is adequate may be some of its components like inductor, diodes in series with the power line are opened, check for any burn marks on the pcb
