Question about U-Line Refrigerators
I have question it does not say on the know but which was do I turn the knob for it to get colder its a u-line refrigerator uln-75th-00
    Habit-Forming:
    New Friend:
  • 30 Answers
Put it in the off position. Turn the knob to the right. If the refrigerator comes on then continue to turn the knob to the right until you get to the temperature you want.The more you turn to then right colder it should be. Turning it back makes it warmer.
Posted on Jan 09, 2019
5 Suggested Answers
6ya staff
SOURCE:
yalmer
Hjalmer Lamminen
  • 552 Answers
SOURCE: Amana Bottom Freezer control knob
http://amana.com
go here and scroll to the bottom of the page and click on "sitemap"
and you will find help information.
Posted on Mar 17, 2008
Anonymous
SOURCE: NO POWER GETTING TO UNIT
realized that there was nothing wrong with the unit....It is suposed to drain out water when running and need to jump start it...so alls good thanks for getting back to us...now were chilling.E.Bates
Posted on Jul 15, 2008
Anonymous
  • 11 Answers
SOURCE: U-Line Model ULN-CLR60B-00
call 1-800-779-2547, U-Line's tech support.
Has to be a bad a switch, wiring issue or maybe a control board. pull the service cover and see if the red light is lit on the board (or flashing). Light on (no flashing) indicates the board is powered up and no errors are occurring.
http://www.u-lineservice.com
Posted on Dec 23, 2008
Anonymous
SOURCE: Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
Posted on Jun 05, 2009
I have a U-Line ULN B198B-00 and the water won't shut off. It ends up filling the ice bucket and overflowing. Could it be a bad solenoid??
If you can get to the solenoid you could remove the solenoid connector. If it shuts off then I would suspect the ice maker timer. if it doesn't shut off I would suspect the water valve/solenoid.
Aug 16, 2014 | U-Line ULNSS1095 Marine Series 12-lb...
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Amana refrigerator knob
More snowflakes = colder. Place a small amount of water in a few cups in various spots in fridge, wait overnight, temp water if you want, otherwise if frozen; too cold.
Jun 21, 2013 | Refrigerators
Motor burnt out model uln-b195btp-11 looking for spare part
Here is the information you requested. To order, click on the add to cart button. results.gif Success, we found the genuine replacement part! Part Type Fan Motor-Refrigerator image-not-available.gif Description
FAN MOTOR FOR REFRIGERATOR
Our Part Number
Use this number to order online. Receive additional discount and free shipping
Z15-ULN-B195BTP-11-509
Price $161.01 Available Yes-In Stock Additional info FAN MOTOR FOR REFRIGERATOR
FREQUENTLY ASKED QUESTIONS-CLICK HERE
http://www.expertappliance.com/partfinder-sz.php
Hope this is the right one for you.
Jun 10, 2011 | U-Line Icemaker
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
Wine cooler #ULN-75BWC-00 motor seems to have shut off and no longer cooling. Please advise possible issues & parts to be replaced. Unit about 7 yrs old.
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Feb 15, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Dean
You can also go to:
Jun 05, 2009 | U-Line Refrigerator Ice Maker
Refrigerators Logo
Top U-Line Refrigerators Experts
Elie Balas
Marvin
Marvin
brokenrubber
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
