You presumably refer to the interior air circulation fan? This usually doesn't operate continuously but runs for a time after the door has been open and with some fridges can be switched off.
If the fan motor has failed it should be possible to replace it but first it is best to know the motor has failed rather than the supply (timer, wiring, etc.)...
SOURCE: Significant fan noise on Westinghouse WSE7000W side by side
you need a new fan motor... the bearings are shot
SOURCE: Our Westinghouse refrigerator RP241T leaks out the bottom
The water that is produced during a refrigerator's defrost cycle drains into a catch basin behind the interior wall of the unit. The water then drains into a tube which carries the water underneath the refrigerator to a drain pan, where it is evaporated by heat from the coils and the compressor. You should be able to see this tube at the back of the refrigerator.
If any part of this drain system gets blocked, the water is diverted before it reaches the drain pan. It sounds like you have such a blockage. In some refrigerators, you can pull this tube loose at the point where it connects with the catch basin. Blow into the tube and see if it is open. If it is, the blockage is likely in the catch basin inside.
SOURCE: Fridge compartment of westinghouse bj433v-r is not
The freezer control on most units is just a door that you open or close to let more or less air into refirig from freezer. The higher the setting, the less air to the frig side.
If frost build-up on freezer side, then you have a defrost problem. Too much frost build-up on evaporator is blocking air flow to refrig.
SOURCE: Westinghouse fridge/freezer (freezer on top) has
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: Hi,I have a westinghouse fridge
Top of Form If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
