Televison & Video Logo
E
Edward De Leon Posted on Jan 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
06 dodge 1500 catalyst
Check engine code 0402 off and on
Jeff McCrea
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on Jan 04, 2019
Jeff McCrea
Expert
Level 2:
Novelist:
Answers
144
Questions
0
Helped
40612
Points
434
Pretty much the only thing that goes wrong with a converter is that it gets clogged or, if it's a honeycomb type, they sometimes break up. In either case, it will need to be replaced. Keep the old one and recycle it. Scrappers pay good money for them for the platinum and palladium in them. Good luck.
5 Related Answers
Anonymous
  • 79 Answers
  • Posted on Apr 09, 2009
SOURCE: 06 Dodge 1500 V8 4.7L: Overheating, Engine Light
Hi
Check for plugged exhaust system. If plugged will cause overheating and misfiring of all cylinders.
Anonymous
  • 55 Answers
  • Posted on Apr 24, 2009
SOURCE: check engine light on code
cheapest thing is get new gas cap, next make sure no vacuum leaks anywhere, the you may need to replace evap purge valve. these systems are junk on all cars and will make you spend lots of money.
ZZZoom
  • 151 Answers
  • Posted on May 10, 2009
This trouble code is Evap Purge System Performance fault. 1) Check for a loose or missing fuel cap. 2) Check for a damaged or missing fuel cap seal. Recheck for other trouble codes. This fault wont cause the stumblering problem. It turns on the MIL lamp to say there leak in the EVAP system.
Anonymous
  • 2559 Answers
  • Posted on May 11, 2009
SOURCE: Code P0430 Catalyst Efficiency below threshold (bank 2)
one of your O2 sensors is showing as bad.
Anonymous
  • 1857 Answers
  • Posted on Feb 18, 2010
SOURCE: 1999 Subruban 1500 LT Failed Emissions Test:
You may have a defective coolant or air temp sensor. These need to be accurate in order for some of the monitors to run. Your going to need a diagnostic scanner to see the data so you can determine what is wrong.
If you had replaced or unhooked the battery just pryor to geting the smog then thats the problem. Just drive the truck for a couple days and you should be fine.
You will still pass the test if you still have 2 monitors not set. California allows that. 3 fail
1helpful
1998 dodge 1500 rejected smog test
you really need to drive it for min of 30 minutes before you go, they need time to heat up and run a cycle,
2helpful
Po430 trouble code
P0430 - Catalyst System Efficiency Below Threshold Bank 2. The most common cause it the three way catalyst converter Bank 2. Common Problems That Trigger the P0430 Code
1helpful
My 2006 dodge ram 1500's check engine light just came on, is there a sequence i can run to get it to give me a code?? i know with other cars, there is. but never had any issues with my 06
The only way to get the codes on a 2006 is with an OBD-2 scanner. Most of the larger auto parts stores will run the scan for you for free.
2helpful
The codes p1596 and 0420 have appeard on my 2002 dodge ram 1500 quad cab and was needing assistance.
The P1596 is Speed Control Switch Always High and P0420 is Catalyst Efficiency Below Normal (Bank 1) and try taking the positive cable off battery for ten minutes and see if that doesn't help that way it will reset the computer and may just drop them codes.
2answers
2001 dodge ram 1500 5.9 wont go over 12 mph
check catalystic converter. could be plugged.
1helpful
2answers
Hi
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
