Question about Water Filters & Coolers
Hamilton Beach water cooler model bl52. The yellow sanitizing light stays on 24/7 and will not shut off. What can I do?
    Master:
  • 385 Answers
You can find the same model here, or purchase a newer model>>>www.discountbargainprices.com
Posted on Jan 05, 2019
6ya staff
SOURCE:
Anonymous
  • 149 Answers
SOURCE: Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Posted on Apr 24, 2008
Anonymous
SOURCE: Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Posted on Nov 05, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
Posted on Mar 17, 2010
VMD011
  • 10 Answers
SOURCE: Hi I have a Model 87307 Hamilton Beach/Proctor
I want to buy this dispenser. Please e-mail me at vmd011@hotmail.com
Posted on Nov 16, 2010
jimedwards20
  • 3 Answers
SOURCE: hamilton beach model 87307 water
Check the fans
Posted on Feb 16, 2012
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Feb 15, 2011 | Hamilton Beach Water Cooler with Storage...
Need to find thermostat for hot water tank for hamilton beach water cooler
Is this model 87307? I want to buy this model. My e-mail is vmd011@hotmail.com
Nov 04, 2010 | Hamilton Beach Water Cooler with Storage...
Mar 17, 2010 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler Model 2202 cold water does not get cold. How can I fix the problem
No Cold Water
Hi. I have a Hamilton Beach Model 2202 and it's been working fine until last week. Now I have no cold water.
Aug 15, 2009 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
Aug 06, 2009 | Hamilton Beach Water Cooler with Storage...
Cold Water not squirting out cold water
To resolve this problem, unplug the dispenser and let it sit for about 24 hours. I had this problem happen to me and I took the unit apart to find out the cause. I discovered that the the water cooling mechanism developed a big chunk of ice inside of it and it basically blocked the flow water. Allowing that ice to melt should resolve this problem. It did for us.
Nov 07, 2008 | Hamilton Beach Water Cooler with Storage...
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Won't Stop Cooling
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Water Filters & Coolers Logo
1,771 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
