Food Processors Logo
S
Sally Gillespie Posted on Jan 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Cuisinart food processor will not start. I have only used it a couple of times.
Jean DeLauche
Level 3:
  • Cuisinart Master 2,911 Answers
  • Posted on Jan 03, 2019
Jean DeLauche
Cuisinart Master
Level 3:
Answers
2911
Questions
Helped
974857
Points
13029
Hello, Sally -
Make sure you have the work bowl properly placed on the base and the lid properly attached to the work bowl. I often have trouble getting the work bowl inserted in the base of our food processor and also have trouble getting the lid fitted into the bowl properly.
Since I have no idea which model of Cuisinart food processor you have, I am unable to advise you further.
You can contact Cuisinart Product Assistance:
US toll free number:
800-726-0190
Monday to Friday, 8:00 AM - 10:00 PM (Eastern Time)
Saturday and Sunday, 9:00 AM - 5:30 PM (Eastern Time)
Best wishes.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Feb 06, 2008
SOURCE: cuisinart food processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Anonymous
  • Posted on Nov 28, 2008
SOURCE: Cuisinart Prep 11 Plus Food Processor - Help!
Not sure if you found the solution by now but we recently had a similar issue. Make sure the bowl is put on such that the handle is facing the front of the processor. There is a little black button that gets depressed when the lid gets put on. We had to get the thing to work one night and spent hours trying to get the processor on and then trying to get a blender to work before finding the problem.
Hope this helps.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 15, 2009
SOURCE: cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 17, 2009
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Sep 29, 2009
SOURCE: My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
My Cuisinart DLC-8S Pro Custom Food Processor needs a detachable stem.
eReplacement Parts states that is the right part.
https://www.ereplacementparts.com/cuisinart-dlc8s-pro-custom-food-processor-parts-c-147322_147329_147425.html
How about direct from Cuisinart Kathleen? Although strangely, they quote part DLC-839ATX-1 as the correct one. Could your processor NOT be a DLC-8S I wonder?
https://www.cuisinart.com/shopping/parts-and-accessories/details/dlc-839atx-1
Cuisinart DLC 7 Super Pro. Is the motor finally "toast"?
Sounds like the Motor's Start Capacitor needs replacing. It gives the motor a big jolt of power to get it running.
Cuisinart DFP-14BCN Capacitor Replacement - iFixit
https://www.ifixit.com > Guide > Cuisinart+DFP-14BCN...
The Cuisinart DFP-14BCN has two capacitors, so these steps may be ... Unplug your food processor before starting any disassembly. ... +7 more badges ...
cuisinart food processor replacement parts - Amazon.com
https://www.amazon.com > cuisinart-food-processor-re...
Results 1 - 48 of 717 - Amazon.com: cuisinart food processor replacement parts. ... Cuisinart Work Bowl for 14-Cup Food Processors (DLC-7, DFP-14).
Food Processor Replacement Parts & Accessories - Cuisinart
https://www.cuisinart.com > ... > Parts & Accessories
Purchase authorized Cuisinart® replacement parts and accessories for Food Processor Replacement Parts direct ... Discontinued 7 Cup Food Processor (DLC-5).
Missing: capacitor ‎' Must include: capacitor
Cuisinart DFP-14BCN Capacitor Replacement - InfoCon.org
https://infocon.org > skills > iFixit > Cuisinart DFP...
PDF Replacing your faulty capacitor will bring power back to your motor, allowing the blades to spin. The. Cuisinart DFP-14BCN has two capacitors, ...
9 pages
Cuisinart DLC-7 & DFP-14 Parts - KitchenWorksInc
https://www.kitchenworksinc.com > cuisinart-dlc-7-dfp-...
Replacement parts for the DLC-7 & DFP-14 model food processors.
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
56helpful
5helpful
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
13helpful
It just stopped working
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
Top Cuisinart Food Processors Experts
vince
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
