SOURCE: Dell Latitude C610 battery claims its too hot to charge....
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
SOURCE: red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code
refers to an power set up problem,see incoming voltage with an
multimeter.......
thank u,,,,,,,,
SOURCE: red led light is flashing while charging and it won't turn on
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
SOURCE: Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
SOURCE: Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Testimonial: "That was the problem, Thanks !!!"
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
