I have a Jacob Brothers piano model number 57866 but I can't find any infor...
by Guest 5 days ago
9
I have a Jacob Brothers piano model number 57866 but I can't find any information on it? Anyone know anything regarding this model?
Posted on Questions & Answers Answer
4 days ago
C. Anthony
Guru
Blogs: 48
Forum: 16,526
Votes: 420
What type of information do you want? you have the piano in front of you!
specifically what do you want to know?
the SN shows 1921 date.
Have you tuned it this year? If the piano will not hold tune to A=440hz, the value would be 0. However, I would think it would hold 440...but I may not.
Call your local piano technician to check it fully.
CAPReply
Most typewriters need to be shut off and turned back on to seat the
printwheel for timeing, if not that make sure wheel is on correctly, if not could be bad prinwheel motor or board, also some such as brothers have to have the cover down, there is a switch that times the printer...
Go to this web site and have your model number to retrive this manual. If your model starts with the letter S go to the S section. They are filed in letter and numeric order
Uninstall your printer driver.Install again your printer driver.If it problem your printer properties.Second thinks,if it problem arise heater or fuser unite please change heat roller,then fix this problem.
Presuming both computers connect to the printer through the network ( the printer is not plugged directly into either ) you probably just need to remove and reinstall the Brother drivers making sure you select Network Printer. Brother drivers are usually pretty good. Some routers stumble on the extremely long device name your Brother gives himself. You may need to access the printer through your browser and change his name to something shorter than 10 characters. Believe it or not, I've seen it help.
