Televison & Video Logo
Abbas prince Posted on Dec 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KVS29MH1 power supply board transistors short every time so please what can I do
matt martin
Level 3:
  • Televison & ... Master 1,259 Answers
  • Posted on Dec 30, 2018
matt martin
Level 3:
Answers
1259
Questions
12
Helped
297443
Points
3635
Not sure what you are repairing. You may have shorting diodes. That is the first place to look. Second would be the five pin regulator. Most generally, the capacitors are fine in today,s electronics, check them anyway. Try that. Thanks for asking, Matt of Martins TV Repair.
5 Related Answers
Anonymous
  • 934 Answers
  • Posted on Dec 21, 2008
SOURCE: dead set, HOT transistor keeps shorting
It's the copper coiled magnet on the neck of the crt closest to the front of the tube.
Anonymous
  • 458 Answers
  • Posted on Dec 01, 2009
SOURCE: HP Compaq NX9420 Laptop Power supply shorted ou
The DC Jack Will Need To Be Visibly Inspected, and Tested ..
Most Likely Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into.....
Though, if you experienced a power surge/dip or similar, You could have shorted out the motherboard....
Anonymous
  • Posted on Jul 28, 2010
SOURCE: LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
Anonymous
  • Posted on Jun 26, 2011
SOURCE: My television model TCL 2027U
my tv tcl 2027u problem stand by power no picture? pls help how to repair....
Akhtar
  • Posted on Sep 11, 2013
SOURCE: HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
hi in tv monetor crt use vertical yoke conaction ok when horezantal yoke conact then tv short pozetion 110volt 42 volt help please
1helpful
Roksan Ka1 MkIII integrated Amplifier preamp works but not power amp. Two fuses on circuit board show no continuity, but are soldered in. What would have caused this and how to repair
Very likely the power amp output transistors are shorted and need to be replaced. The fuses provide power to these transistors. To verify this diagnosis, (with the speakers disconnected and the unit unplugged, of course!), check for continuity between the fuse terminal and the speaker output at the amplifier board (before any protection relay). If you have continuity (< 1 ohm resistance), the transistor is bad. Most power amplifiers have one transistor to the DC+ power supply and another to the DC- power supply. Both are connected to one speaker terminal, and the other speaker terminal goes to power supply ground. If one transistor shorts out, it overloads the other transistor and fries it as well. Even if it tests good, it's probably been damaged and is likely to short and ruin the new transistor, so replace both at the same time. The foregoing holds true if the output transistors are inside a power amp module.
Note: check your speaker wiring (both ends) after repairing the amplifier. A stray strand at the speaker connector shorting to the other terminal or ground can destroy the output transistors. I once had a customer who had too much bare wire exposed on the ends of his speaker wire. It was fine until his wife turned the speaker upside down during cleaning and twisted the bare wires together (and forgot to right the speaker afterwards). He bought fuses and transistors ...
3helpful
2answers
3answers
TV went out.
U have a dead power supply board,burn componnents parts on the power supply board.Replaced the power supply board,u will get ur power back as normal function as before.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
2helpful
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
1helpful
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
I have an audiobahn A8000t amp with the protection light on
Note:
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
