Greetings, I read your question and I think Reliable-Store.com can help you in this. Here's the site link
https://www.reliable-store.com
SOURCE: power door lock quit working on rear door
The most likely cause is a defective lock actuator.You'll have to pull the door panel to get at it.Unplug the connector,and rig a 12v test light across the two connector pins.Pressing the lock or unlock button should make the light come on(lock or unlock just reverses the polarity).If you get a light,then the actuator is the problem.If not,then trace back towards the lock relay to find the open in the circuit.
Sounds like the hydraulic system has air trapped in it.
