SOURCE: have a old candy floss machine don't know the make
Hi Tracy, I need more information if i am to try and help ! e.g. approx size and shape, what is the facia like, does it have a cage and element or does it have the new style gauze and kettle element coil ? At a guess i would say it has the old cage and element ( this is a ring covered in viterous enamel and it has slots all the way around, just behind this is a bright silver coloured element which looks like it has vertical slots.A common problem is the coating of the outer cage breaks up and this causes a dead short on the machine which either blows a fuse or even worse does not blow a fuse and tries to heat up like an electric fire!!! Without knowing the machine i could not say for sure but i think the outer cage that holds the element is at fault, but unfortunately normally when this goes to dead short it normally takes out the heat control as well. But there is a way to test this. let me know more info !!!!
SOURCE: I need instructions on how
Thank you for posting on FixYa. I might be able to help if I knew your model number.
