Question about Bush Dishwashers
What else can I do to stop the E2 error code bleeping on my bush dishwasher? I have changed inlet pipe so no problems there. Can you suggest anything else for me to try.
  • 1,234 Answers
Have you disconnected the power to it for 5 min maybe more not sure about what bush model you have.
That'll reset it most of the time.
Posted on Dec 27, 2018
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
NateOcean
NateOcean
  • 14 Answers
SOURCE: Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Posted on Apr 11, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: i have an lg dishwasher mod#LDF7811ST, get error codeIE, changed the inlet valve, machine worked once then got IE error code again. Any suggestions?
If you are getting a IE or similar error on your LG dishwasher and have not been able to solve the problem using information based on that code, check the serial number of the dishwasher. If the first three numbers are between 501 and 702 you may have this problem:
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Posted on Apr 29, 2009
Anonymous
SOURCE: Error code E2
Hi most of the treadmill with e2 error code are related to the motor speed sensor so check the sensor
Posted on May 20, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
Hi. I have Samsung dishwasher DMS500TR has E2 error code, how to fix it, also how to hard reset the machine? Thank you in advance
The E2 code is a water supply error.
The water inlet valve has stopped working.
Try going here...
appliancepartspros.com
with the model # and you can look up the part and how to put it in.
Tis not hard. A phillips & flat blade screwdriver and some pliers.
Mar 04, 2018 | Samsung Dishwashers
E2 error code on Bush dishwasher, how do i fix it?
It is a water inlet malfunction, is the flow valve to the pipe turned off or is there a coil/loop or a bent part of the water pipe that fills it? Or is the pipe to long which causes movement when filling which alters the water rate that upsets the sensor?
It will be one of these options which will quickly resolve the issue, I do hope this helps.....
Mar 01, 2018 | Bush Dishwashers
E2 error code bush dishwasher
I believe that error relates to over fill, i.e., too much water in wash sump. Check drain operation and also fill solenoid for letby
Jan 07, 2018 | Bush Dishwashers
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Gets a 1E code. already checked water is on
Hi shadyron11,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 08, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Displaying code IE
Hi jakkirker,
Kind Regards :-)
Jedemeyer1
Jun 15, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My lg ld 1403w1 dishwasher fills with water and then error code I.E appears have bailed out water and tried it three times same result
Hi june1245,
I.E means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame (varies on model) - Make sure of the following first:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Un-kink it.
Kind Regards :-)
Jedemeyer1
Jun 06, 2011 | LG Dishwashers
Lg dishwasher LD-12aw2
IE is a INLET ERROR. Possible causes ¥ The Water Tap not opened.
¥ The Inlet Hose is kinked.
¥ The Filter of inlet valve clogged by
impure water.
¥ The Inlet Water Valve is normal ?
¥ The water pressure is very low.
( below 0.3 kgf/ )
Possible solutions ¥ Open the Water Tap.
¥ Repair the Inlet Hose.
¥ a) Close the Water Tap.
b) Unscrew the Inlet Hose (Inlet
Valve side)
c) Clean the Filter of Inlet Valve.
¥ Replace or repair the Inlet Valve.
Feb 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
59 people viewed this question
Top Bush Dishwashers Experts
vince
Marvin
Marvin
Jem
Are you a Bush Dishwasher Expert? Answer questions, earn points and help others
