Video Game Consoles & Games Logo
JulezKarma DGAF Posted on Dec 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ps4 wont show on my tv although it turns on, Im thinking its the hdmi port
john eddy
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Dec 27, 2018
john eddy
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
323
Points
1st. Try a different hdmi input if you have another on tv.
2nd. Try a different hdmi cable.
3rd. Connect the system to a different tv to make sure it is working on another tv.
If these do not work the issue is with game system.
Giselle
Level 3:
Genius:
  • Sony Master 1,015 Answers
  • Posted on Dec 26, 2018
Giselle
Sony Master
Level 3:
Genius:
Answers
1015
Questions
6
Helped
286174
Points
2407
Buy cd keys on https://www.m8x.com, cheap and legitimate cdkeys offered there
5 Related Answers
Anonymous
  • 54 Answers
  • Posted on Jan 21, 2009
SOURCE: tv converter
there is no way to convert your antenna/cable wire to use either hdmi or dvi. you must use either a cable box or satellite reciever. on any new tv sold within the last year there is a " rf connector " where you would attach the antenna or cable wire. take a look at your owners manual to find out exactly where.
Anonymous
  • 668 Answers
  • Posted on Jun 18, 2009
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
nelsontimmy
Tim Nelson
  • 83 Answers
  • Posted on May 21, 2010
SOURCE: Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
Anonymous
  • 1112 Answers
  • Posted on Jan 24, 2011
SOURCE: i have a kde-50xs955 sony
HI:
You need to replace the analog board assembly, this is the board that you plug connections into, seems the HDMI port has malfunctioned, there may also be a problem with the main board assembly that the analog board connects to.
Anonymous
  • 358 Answers
  • Posted on Feb 02, 2011
SOURCE: New TV is hooked up
jason_janick
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
Sony PlayStation PS4. How to hook to my 2009 19 inch Sansui television please?
Question edited for clarity.
For a definitive answer, the television model number should have been added to check specs.
Can't get video to work on tv. Sansui HDLCD19WB and not ...
JustAnswer https://www.justanswer.com > TV Problems
Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ...
1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
Can I connect a PS4 into any LED TV?
Quora https://www.quora.com > Can-I-connect-a-PS4-into-any-...
May 3, 2018 - Usually PS4 is connected to a HD TV or 4K TV through HDMI cable which is the most obvious method. PS4 console has HDMI port just for the obvious ...
4 answers · Top answer: Hey man thanks for the request The ps4 console is connected to the tv through an HDMI cable ...
Will a PS4 work with any TV? - Quora
May 26, 2018
Can a PS4 work with a 1366x768 TV (vu 32-inch ...
Nov 22, 2017
Will PS4 slim work with any TV? - Quora
Apr 5, 2017
Are Sansui 4k LED TVs any good? How do they ...
Nov 26, 2016
More results from www.quora.com
Connecting Kenwood vr-405 to ps4
o connect a Kenwood VR-405 to a PS4, you will need to use the audio and video outputs on the PS4 and the audio and video inputs on the Kenwood VR-405. Here are the general steps to follow:
  1. Connect the HDMI cable from the PS4 HDMI Out port to the HDMI In port on the Kenwood VR-405.
  2. Connect the audio cable from the PS4 Digital Out (optical) port to the Optical In port on the Kenwood VR-405.
  3. Turn on the Kenwood VR-405 and set the input to HDMI or Optical, depending on which cable you used.
  4. Turn on the PS4 and adjust the audio settings on the PS4 to output audio through the HDMI or Optical connection.
  5. Adjust the audio settings on the Kenwood VR-405 to match the audio settings on the PS4.
It is important to consult the user manual of both the Kenwood VR-405 and the PS4 for specific instructions on how to connect them and adjust the settings. If the VR-405 doesn't have a HDMI input, you can use an HDMI to composite adapter to connect the PS4 and the VR-405.
Ok I’m trying to plug my ps4 into my dell monitor but it keeps saying Cannot use video (That’s paraphrased) and stuff like Optimal Resolution is 1680 x 1058 60hz
no monitor stated,
sony play station 4 sure.
but what cable are you using.? (video) HDMI, , and does this cable work from TV hdmi to PS4, showing SOny is ok.
can i presume the monitor has HDMI and you are not using a
funky, hDMI to VGA or DVI adaptor????
also DRM can get in the way here.
or very old monitors HDMI not up to work with Sony.
PS4 web site lists monitors that work. if you want to read that.
but if you read your SONY manual and see what the default resolution is, then go to the monitor push menu and change it.
quote sony
but it should be HDMI automatic and if is the sound can see be dead if the monitor has no speakers, but there are ways to cure that.
"When you set up your PS4™ system, you might need to configure the output for the HDMI OUT port. By default, this is set to automatically match the TV you connect. To configure settings yourself, select (Settings) > [Sound and Screen] > [Video Output Settings]."
2answers
Trying to hook up a PS4 2A Oli flat screen TV help please
its a ps4 so it comes with a hdmi cable. Place the hdmi cable into the back of the ps4 and put the other end into a hdmi input
on the TV . Don't know the TV but usually there are a number of HDMI input ports on most modern tv's.
Then switch tv source to HDMI .
Happy gaming Phillip
you will have to plug the usb cable into the controller and into the front of the PS4 and then charge the controller by pressing the power button on ps4. The controller has to be paired to the ps4. The manual that came with the ps4 should go into it in more detail.
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
I have a ps4, when I turn it on the blue light will come on and then it'll go to the white one and there is no image on the t.v. even the homepage on the ps4 won't even show. Anyone know why?
How do you connect a ps4 to the tv
  1. Plug the included HDMI cable into the HDMI Out port of the PlayStation 4.
  2. Connect the other end of the HDMI cable into an available HDMI In port on your TV.
2answers
Blue light comes on but does not show to t v
Its known issue with the PS4s that some when inspected at the factory they forgot to bend a piece of metal down in the HDMI port. If you take a light and look into the HDMI port you will see a small metal prong sticking up, you need to bend that down as shown.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
