Make : Sony Model No : KDL40EX720
SOURCE: display on monitor has swapped from vertical to horizontal
Type ctrl-alt then use the up, down, left, and right arrow keys until it's where it's supposed to be. If that doesn't work, right click on the desktop, select graphics properties. Then there should be a display settings, there you'll see where you can change the rotation of the display.
SOURCE: Motorola W385
how to donw load pictures from my cell fone to my pc, do i need soft were? , usb cable is fine...
SOURCE: kenmore model c970-655632 LED Display is very dim
hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
SOURCE: Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
SOURCE: dim LED display on oven
You need to replace the capacitors on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there. Faults to Plasma TVs are described in detail there. Check it. Just see, almost all Plasmas are built on same type chassis and board configuration, so the fault to these sets too will be almost the same in nature.
