Question about Water Filters & Coolers
My hamilton beach bottom load water dispenser is not cooling the water what can i do?
    Top Expert:
  • 66,070 Answers
CHUCK IT AND GET A GOOD ONE
Posted on Dec 22, 2018
6ya staff
SOURCE:
Anonymous
  • 149 Answers
SOURCE: Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Posted on Apr 24, 2008
1tonchev
SOURCE: hamilton beach 4200 water dispenser
i have had this unit for 2 years and the first thing that will go out is the cooling fans, they either stop altogether or start making a loud noise. i suggest to anyone else who has this to go to a computer store and buy 2 quality 90mm fans, they will screw and connect right into the unit. mine initally died about 4 months into use and after replacing them with good fans i never had a problem with it. mine however is a dust magnet and if i dont remove the fans and clean off the heatsinks about every 3 months, the water wont get very cold. mine now is starting to leak water, a big loss since we use this thing all the time.
Posted on Jun 06, 2008
ghost_balls
  • 14 Answers
SOURCE: Hamilton beach water cooler is not cooling
Sounds like the fans have stoped turning for the cooling system. If you cannot hear the fans turn on when you flip the COOL switch this is your problem. Pick the fans up at a computer parts store like Frys. Any other part failure on this unit other than a loose wire is not worth repairing. A little oil inside the motor and several revolutions later might get some relief until a new motor is installed.
Posted on Jul 10, 2008
Anonymous
SOURCE: Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Posted on Jun 10, 2010
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: do I put water on
Are you trying to keep things warm, like with a warmer tray? then it will be fine if you add water, and this can also keep the food a little moister from the steam. it is not neccesary to add water but you can. Water will leave a deposit line inside the unit when it heats up and starts evaporating, this won't hurt anything and you can clean it with some cleaner and a scrubber. If your a cooking with it, then you don't want to use water, just put the food in the insert and cook it like that.
Posted on Nov 25, 2010
Water dispenser BL-5-2 need to replace pump or get new part that connects to pump?
Fixya is unable to suggest sources for Hamilton Beach products other than Hamilton Beach
Aug 22, 2018 | Water Filters & Coolers
Hamilton Beach water cooler dysfunction.
Check to see if the dispenser has an integral water filter. If yes, replace it to improve the taste of the water. If no, then unplug and remove the top panel and shut off the water supply line to the unit.
You'll want to drain the cooling tank and clean it with some white vinegar to remove any mineral deposits that could be affecting the taste of the water. You'll want to lightly scrub the inside of the chilling/cooling tank with a mixture of at least 2/3 white vinegar and warm water to help dissolve any residue in the tank.
After you've gotten it as clean as possible, turn on the water supply line and flush the tank by filling a pitcher from the cold water dispenser. Do this for at least 2-3 gallons of water to completely clear out the vinegar mixture.
You'll also want to remove and sanitize the dispenser valves on the front of the unit, as there could be some gunk inside the spout that is adding to the foul taste and odor.
I would also suggest you install an inline charcoal water filter to the supply line serving this cooler, as that will only help improve the taste and clarity of your drinking water.
You should be able to adjust the temp of the cold water with a thermostat controler located inside the cabinent. You might want to contat Hamilton Beach to obtain an owner's manual for your unit to get more detailed information about use and operation recommendations.
Hope you found this info very helpful and best regards!
Aug 06, 2009 | Hamilton Beach Water Cooler with Storage...
Tanks leaks, where can i find a replacement tank??? Hamilton beach model 47224
I called up Hamilton Beach directly and ordered a new one. Fits fine and works like new:
USA
1-800-851-8900 (all products except microwaves and water dispensers)
1-800-488-5080 (microwaves and water dispensers only)
Canada
1-800-267-2826 (all products except microwaves and water dispensers)
Mexico
01 800 71 16 100 (all products)
Send a fax:
1-800-230-4708 (toll-free within the United States)
Write a letter:
Hamilton Beach Brands, Inc.
360 Page Road
Washington, NC 27889
Have to call weekdays normal business hours....no weekends
May 10, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Broken gear
Hamilton Beach parts are not readily available form parts suppliers. Here is contact information for Hamilton Beach.
USA
Canada
Mexico
Send a fax:
Write a letter:
360 Page Road
Email: (Please allow 3 business days for a response)
For all products except microwaves and water dispensers: Click here to send email..
Jan 17, 2009 | Food Processors
Glen,
Sep 01, 2008 | Refrigerators
Won't Stop Cooling
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
MY HAMILTON BEACH WATER DISPENSER MODEL 87307 SERIES A1360CT WILL HEAT BUT NOT COOL THE WATER.
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Apr 21, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Water Filters & Coolers Logo
676 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
